E M P Offline Image Upload: Off
p.1 #11 · Alyssa and relfector question | |
In the shade you often don't need a reflector. The ambient light is diffused and bounces around enough to fill in the shadows. Place your subject in the shade and you'll see right away that the light is more even all around.
Also, a reflector works even in the shade; it will just be a more subtle effect. Sit your subject in the shade and hold a white or silver reflector to the side of her face (or have an assistant hold it), just barely out of the frame. You'll see that side of her face brighten a bit. This is often helpful if you need just a touch more light in the eyes (a common occurence). Reflectors also can add catchlights in the eyes, which helps make the subject appear more alert and interested.
Lastly, about shooting with the sun behind the subject: each lens handles flare differently. You'll have to experiment to find out how susceptible your lenses are to flare. However, usually you won't have flare unless the sun is shining almost directly into the lens. This will not happy unless it's very early morning or just before sunset -- when the sun is very low on the horizon. If you shoot, say, 4 pm, the sun will be high enough not to cause flare in your lens. So yes, face your subject away from the sun and let the sun shine towards you. The sunlight will create a "rim light" around the outline of your subject's head and body, which will be very attractive (although you will need some kind of reflector or flash to light up the face a bit).
Alternatively, if your lens is really sensitive to flare or if the sun is very low on the horizon, you can put it off to the side but still behind your subject. This will provide a "rim light" on just one side of your subject's head, but is still enough to provide some nice lighting. Just be careful the sun is not off to the side enough to hit the side of her cheek unevenly.
Generally speaking, I will not schedule shoots between 11 and 3. If I absolutely must fit a shoot in during that time, I will shoot almost totally in the shade. I NEVER shoot with the sun shining into my subject's face, no matter what time of the day (although some photographers do -- it really depends on your style).
