2 end
Archive 2009 · Lenses for Alaska cruise
nick53097
p.1 #1 · Lenses for Alaska cruise
I am taking my Nikon D300 and 17-55 for Alaska cruise next year
What would be the best telephoto lens (Nikon 70-300 or Sigma 50-500, or something else)??
Nov 18, 2009 at 01:34 PM
Two23
p.1 #2 · Lenses for Alaska cruise
For the money, the best would be the Nikon 80-400mm VR. The 70-300mm VR would be a very good budget choice. I don't think the Sigma 50-500mm has OS (OS=VR) so I'd rule that out as it would need a tripod. The newer Sigma 150-500mm lens does have OS, but it's f6.3. That's pretty slow and the camera will have some trouble with autofocus, especially in low light. The light levels are often low due to heavy cloud cover. SO, my first suggestion is Nikon 80-400mm VR which is a sharp lens and the VR works. It's a good general purpose lens. AF is not fast but you won't need it to be. I do not suggest any lenses that do not have VR (or the equivalent) because with longer lenses you would then need a suitable tripod. Not sure how well taking a tripod around would work for you, and it takes a pretty decent one at that. Budget another $400 for a decent used one.
Kent in SD
Nov 18, 2009 at 01:49 PM
jonshonda
p.1 #3 · Lenses for Alaska cruise
How often do you go to Alaska, and how much $$ can you spend? If its a once in a lifetime, will that change your outlook on lenses?
Nov 18, 2009 at 02:41 PM
KIDERAL
p.1 #4 · Lenses for Alaska cruise
I would bring a 20x zoom P&S.
This would cost less than a good dslr zoom.
Hopefully you will be shoot whales and glaciers and you need to pull them in.
You probably can go wider for the landscapes.
Nov 18, 2009 at 02:57 PM
loggerhead
p.1 #5 · Lenses for Alaska cruise
I had a similar decision to make earlier this year. Our trip was a little different, we took the Alaska Marine Highway system from Juneau to Skagway, and were then doing a 5 night trail hike. The hike drove the gear decisions, the D3 stayed home. I was very happy with my new D5000 with the 14-24 and the new 70-300. I think you'd be pretty happy with the 17-55 and the 70-300. Sure, you can spend lot's more money, I left a 70-200 home. The 80-400 isn't anything special for the money.
I'm tempted to pick up the cheap Vivitar MF 800mm. When you need long, you usually need really long. If your trying to take a quick shot of a whale off a moving ship this lens would probably be fine, usually focused at infinity. It would be hard to take a good picture at that focal lenght off a moving ship.
Nov 18, 2009 at 03:27 PM
edk99
p.1 #6 · Lenses for Alaska cruise
You might also consider renting a lens. Maybe a 200-400 f4 VR.
Nov 18, 2009 at 03:28 PM
nick53097
p.1 #7 · Lenses for Alaska cruise
It is once in a lifetime (at least for today) and budget is limited
For Nikon 70-300 VR can I use any tubes to extend a telephoto reach?
Nov 18, 2009 at 03:59 PM
lou f
p.1 #8 · Lenses for Alaska cruise
shooting from a boat, of any size, with a tripod is worse than pointless. engine vibrations and its not steady so get a vr lens 70-300vr or the longer 80-400vr and hand hold.
Nov 18, 2009 at 04:13 PM
90 5.0
p.1 #9 · Lenses for Alaska cruise
rent the 80-400vr
Nov 18, 2009 at 05:41 PM
skyvan
p.1 #10 · Lenses for Alaska cruise
I'd say rent the 80-400VR if you think size will be an issue but if you really want to get cool shots maybe spent a little more and rent the 200-400 as it has good VR and is f/4 throughout, it is a big lens but it has the advantage of being able to still focus with a TC on it, something that the 80-400 will struggle with given its f/5.6 at 400.
Nov 18, 2009 at 08:12 PM
galenapass
p.1 #11 · Lenses for Alaska cruise
http://www.lensrentals.com/
I just received and lens today from this outfit (will be in Ecuador next week). I have had nothing but great service from these guys and recommend them without hesitation.
Nov 18, 2009 at 09:17 PM
EB-1
p.1 #12 · Lenses for Alaska cruise
This year the 16-85 and 80-400 worked very well as a lightweight combo. The VR is invaluable. The tripod was rarely used (only on a couple of land excursions), but you might bring a small one if feasible. Keep in mind that I'm speaking for a serious, but not hardcore user. The 12-24 was also used, though to a lesser extent.
Nov 19, 2009 at 01:23 AM
Hamishhog
p.1 #13 · Lenses for Alaska cruise
+1 (2, 3 4 5, 6, ?) for the 80-400.
I worried about what to bring to Scotland this summer and decided on this lens.
I worried especially about the light (similar to AK maybe?) but can't imagine a better choice and was on ferries a lot.
Nov 19, 2009 at 03:27 AM
jamach
p.1 #14 · Lenses for Alaska cruise
sure, but you lose autofocus, would be 3d party TC's
80-400 would be great choice - I know a photog who took the cruise an dthe main lens was the 100-400
Consider you will have indoor shots, outdoor shots, and maybe small boat shots chasing whales
Take what you can to get all the shots.
And also a laptop or some device to offload the memory cards, unless you will bring a box of them
Don't forget the battery charger
Nov 19, 2009 at 03:48 AM
Fishinfool
p.1 #15 · Lenses for Alaska cruise
As Louis said, VR is important as deck vibrations will hurt immage quality if you use a tripod while underway. Most of your shots will be handheld. I own and often use the 80-400VR Nikkor, and it would be a good choice. From what I hear, the 70-300 VR is also a great lens for the money. When you start talking about using TC's or tubes, I think you are going to run into the situation of blurry pictures do to lack of speed / light while at high magnification. Now if $ was not a factor, the 300 f2.8 VR with a 1.7 TC would be a nice combo..
Larry
Nov 19, 2009 at 05:30 AM
nick53097
p.1 #16 · Lenses for Alaska cruise
Thank you all
Seems like 80-400 is the winner
Nov 19, 2009 at 01:25 PM
Chris Noyes
p.1 #17 · Lenses for Alaska cruise
I took an Alaska cruise two years ago and brought along my 70-300 VR. It did a great job from the ship deck, and I was often shooting next to a guy with the 80-400 VR. My 70-300 acquired focus a bit faster, but lost a little on the reach (which was often needed in Alaska, but not necessarily when on the ship).
D80 w/ 70-300 VR @ 122mm
D80 w/70-300 VR @ 70 mm
After departing the ship, we went to Denali NP, and that's where I would have given my right arm for some long glass. I still got a few decent shots . . .
D80 w/ 70-300 VR @ 70 mm
Here's where I would have liked more than 300 mm . . .
D80 w/ 70-300 VR @ 220 (this was the best I got of these two, none of the 300 mm came out sharp enough for me . . . more attributed to my lack of skill and shooting from a moving bus)
Nov 20, 2009 at 12:53 AM
nick53097
p.1 #18 · Lenses for Alaska cruise
Have anyone try new Sigma 150-500 HSM OS?
Sounds very interesting
Nov 20, 2009 at 03:42 AM
Two23
p.1 #19 · Lenses for Alaska cruise
No, but note it is f6.3. Way too slow for me to consider. Many kinds of wildlife come out in lower light levels such as twilight. Might work for birds in bright sunny conditions.
Kent in SD
Nov 20, 2009 at 04:21 AM
90 5.0
p.1 #20 · Lenses for Alaska cruise
Chris 1/50 is pretty slow for moving animals, I try to stay at least 1/100 if they aren't doing much and 1/500 if they're active. That's using short lenses or lenses with vr were the vr can take care of the camera shake sometimes but mot your or the animals movement. I see the bears were at iso 100, with the D80 I would have been comfortable shooting up to 800 in that scenario and gone for some higher ss.
Regardless looks like it was a fun trip!
Nov 20, 2009 at 05:59 PM
Avi B
p.1 #21 · Lenses for Alaska cruise
I would honestly pick up a used AFS 300 f/4 and the 1.7TC. After the trip, sell off.
Nov 20, 2009 at 06:49 PM
allstarimaging
p.1 #22 · Lenses for Alaska cruise
lensprotogo.com and rent a 200-400F4. More reach than the 70-300 and a significant improvement in IQ on the D300 it will be a great set up. Hope you have a great trip.
jack
Nov 20, 2009 at 06:53 PM
lou f
p.1 #23 · Lenses for Alaska cruise
the 80-400vr is great really delivers when stopped down. this was shot with a d2h a while back no probs with focus tracking. the second was with a d200.
Nov 20, 2009 at 10:08 PM
kwilliam8
p.1 #24 · Lenses for Alaska cruise
I did the inside passage cruise to Alaska in 2007 and 2008. I took both the 70-300 VR and the 80-400 VR. Besides the 70-300 being smaller (and much cheaper), I was really pleased with the quality of the pictures taken by the 70-300. Many of my pictures where hand-held, and the smaller lens just took sharper pictures in my opinion. For my tastes, I hardly needed the extra reach of the 80-400. On the second cruise, I hardly used the 80-400 at all. You can see photos from both of my trips at http://kwilliam8.smugmug.com/. For almost every picture in the website, if the focal length is over 200, it will have been taken with the 70-300. Take a look and see the quality for yourself (keep in mind I sharpened them in Photoshop). I am actually thinking of selling my 80-400. Enjoy your cruise - it will be a trip of a lifetime!
Keith W.
Nov 20, 2009 at 11:39 PM
wingcommander
p.1 #25 · Lenses for Alaska cruise
If you're after speed- Sigma 150-500 is f6.3 at 400 mm, Nikon 80-400 is f5.6 at 400, and 300 f4 with 1.4 tc is f5.6 at 450 mm. Pretty much a wash as far as speed is concerned. If you really need speed the (pretty expensive) Nikon 200-400 gets you one whole stop. (a bit more over the Sigma) That helps, but it sure doesn't get you into an entirely different world.
Nov 21, 2009 at 12:13 AM
2 end
