Will the camera continue to operate if this battery failes? If so, what information will be lost? Obviously the dat and time, but will settings and file numbering be effected?
When I do change it willI end up with file number the same as some I already have?
I'm just wondering if I should be carring around a spare.
you will loose the camera info if you remove the battery or it fails.
when you replace the battery put a non formated card with the last sequence of shots you took before you replaced the battery and it should carry on from the last file number
