2 end
Archive 2009 · Clear Filter = Soft Images ?
woodfin
p.1 #1 · Clear Filter = Soft Images ?
I'm looking for a little expert advice.
I have a Nikon 300MM F4 on my D300. It's rock solid and tack sharp...Without a filter on the front.
I bought a Tiffen Digital HT Ultra Clear filter. It's an expensive clear filter that when I look through it is... Crystal clear. But, every image I take with it is very soft. Not just a little back or front focus, but a terrible looking, out of focus shot.
Any thoughts on what would cause this ?
Nov 17, 2009 at 03:18 AM
trenchmonkey
p.1 #2 · Clear Filter = Soft Images ?
Adding any glass to the optical path will have an impact. The lens was engineered to perform with "X" amount of elements.
Unless shooting in blowing sand, salt spray, ground level motocross rooster-tails etc.... just use your hood.
Nov 17, 2009 at 11:15 AM
hjanssen
p.1 #3 · Clear Filter = Soft Images ?
What is it: soft or out of focus, a soft focus is in focus but soft.
Nov 17, 2009 at 12:58 PM
LeifG
p.1 #4 · Clear Filter = Soft Images ?
A high quality filter should have negligible impact on IQ.
Nov 17, 2009 at 01:24 PM
skyvan
p.1 #5 · Clear Filter = Soft Images ?
I think that your filter may be warped and therefore causing some weird image problems. It is true that even a good filter will alter the optical engineering a bad quality filter can really screw it up. That's why i decided to invest in B+W filters on the lenses that i use the most and I have Hoya HMC filters on lesser used lenses. I used to have some Tiffen UV filters and had nothing but problems with them, additional flare, breaking when being installed on lens thread, etc. Only Tiffen things I have now are CPs which I don't feel there is a need to invest in good ones considering how rarely I use them (haven't used one in at least 3 months). I recommend trying it with a B+W filter, that should solve your problem.
Nov 17, 2009 at 01:39 PM
Alan321
p.1 #6 · Clear Filter = Soft Images ?
A defective filter can be loose within the filter ring and cause some image softness due to the filter element moving. Not common but it happens occasionally.
Other than that, if the filter is uncoated or poorly coated on the lens side then it can introduce additional reflections that contribute to ghosting or flare on the image sensor. I don't know what coatings your filter has.
In my opinion TM's advice is good.
- Alan
Nov 17, 2009 at 01:40 PM
Rodolfo Paiz
p.1 #7 · Clear Filter = Soft Images ?
Also, if you feel the filter is truly causing a problem, simply ask the manufacturer for a replacement under warranty. Or if you prefer to go the retailer route, and you bought the filter very recently, you may be able to return or exchange with directly with the retailer at which you bought it.
Nov 17, 2009 at 02:13 PM
Two23
p.1 #8 · Clear Filter = Soft Images ?
I almost never use filters on lenses, except a polarizer when needed. They have a way of causing me problems. When I buy a lens on eBay and it comes with a filter on it, I throw the filter away first thing. I do use the tough lens cap to protect my glass though, and lens hood. My lenses are perfect.
Kent in SD
Nov 17, 2009 at 02:19 PM
Baywing
p.1 #9 · Clear Filter = Soft Images ?
Even the very best filter is going to add 2 air to glass surfaces for the light to go thru, multicoating helps, but there will be light losses and reflections. Tiffen is probably the worst I've seen, Hoya is better for the money, Nikon, Heliopan and B+W are the best. Sounds like you got a really bad filter, the worst I've seen so far is an overall softness with lack of contrast. I met a guy years back who was selling a 300 f4 (early AF). I put the lens on my F5 (yes, I said it was years back!) and the image was horrid, soft, milky and lacking contrast and snap. I looked at the front of the lens and low and behold, a clear filter (Tiffen at that!). I removed the filter, image quality improved dramatically. I showed the seller, he was amazed. The lens was a little more beat up than I wanted and now that it seemed sharper, he decided to keep it.
I prefer to use a lens hood for protection in all but the worst conditions, when I use a Nikon L1bc.
Nov 17, 2009 at 04:10 PM
traveler
p.1 #10 · Clear Filter = Soft Images ?
For well over a decade now, I've been using the best Hoya and B+W UV's on the end's of the best glass I could buy. I've NEVER (and I do mean NEVER) gotten a shot with lowered IQ as a result of this behavior. I've read reports and reviews of others that have had all kinds of issues with use of filters on the end of good or great glass. The theories abound, and while they may seem to make perfect sense, try as I may, I've tested and worked with many and have never gotten ANY loss of sharpness, contrast or flare from using them. Either my angle of incidence has been perfect to avoid these issues, or I'm just sticking with good filters overall. Ya'll can argue this till the cows come home. If you are paranoid about using a quality filter don't. That simple. As for "assuming" it will "automatically" reduce the IQ please spare me the diatribe. Been there done that. Not interested. It makes about as much sense as assuming if you don't get the swine flu shot you are doomed. I won't bore you with the argumentative details regarding the OTHER end of those that subject themselves to being medical experiments in the grand scheme of the medical and political world. I just wish this whole filter vs. no filter argument would die, but it keeps getting life, and the passionate arguments continue on both sides. I'm a protectionist believer. Hoods are fine for obvious obstructive damage, but do next to NOTHING for environmental intrusion. Be it dust, general schmutz or whatever. You can do as you wish. I've made my decision and it serves me just fine.
Nov 17, 2009 at 04:58 PM
Rodolfo Paiz
p.1 #11 · Clear Filter = Soft Images ?
Not that you have strong views on the subject, or anything like that...
Nov 17, 2009 at 06:31 PM
billkoe
p.1 #12 · Clear Filter = Soft Images ?
Shooting with a "clear" filter is like shooting through a window. Unless you're shooting in the desert, I'd take full advantage of the wonderful glass that Nikon makes and leave it off. It's like the friends of my parents that always had a plastic cover on their expensive couch.
I've shot Canons, Nikons, Leicas and Hasselblads for 35 years and never had a problem for lack of a "clear" filter.
Bill
photo-synthesis
Nov 17, 2009 at 09:15 PM
woodfin
p.1 #13 · Clear Filter = Soft Images ?
Thanks for the great feedback, It's definitely the filter. I took some more shots with it today in bright sunlight, setup on a tripod. I was in a garage well back from the direct sun and shooting out into the sunlight (Sun was behind me)
I did a series of three test. One set without the filter, one with the filter and one without the filter, but a clear piece of single pane window type glass pressed flush to the end of the lens (Not touching...Just pressed against the ring)
The test without the filter and with the plain piece of glass looked great, the one with the filter looked terrible.
I'm still shaking my head... It must be the special super duper coating that is screwing it up.
I've called tiffen and sent a email, but have not heard back.
Nov 17, 2009 at 10:09 PM
LeifG
p.1 #14 · Clear Filter = Soft Images ?
Bill
photo-synthesis
A quality filter is nothing like a window, if by which you mean the kind found in a house. That glass is produced by floating molten glass on a bath of molten metal.
I have Canon Protect filters on a couple of lenses and a spotting scope and tests showed no detectable impact on resolution and contrast when used on a D200, although there is bound to be an increased tendency to flare in certain circumstances. I have not tested on FX, so for me that remains unknown.
I think the main advantage of filters is that if you buy a lens which has always had a filter on it, the chances are the owner has never touched the lens's front element, but has probably abused the filter e.g. using a cloth or even a hankie to 'clean' the filter glass.
Nov 17, 2009 at 11:10 PM
Elan II
p.1 #15 · Clear Filter = Soft Images ?
That filter thread at the front of the lens.. what do you think it's there for?
Nov 18, 2009 at 12:17 AM
trenchmonkey
p.1 #16 · Clear Filter = Soft Images ?
Cir Pols when the situation calls for it, smart ass.
Nov 18, 2009 at 12:36 AM
Rodolfo Paiz
p.1 #17 · Clear Filter = Soft Images ?
Graduated ND's, ND's, color filters, polarizers, warming filters, cooling filters, infrared filters... lots of choices out there. Absurd to imply that a UV filter should be there just because there's a ring there. Or perhaps you were not aware of all those other uses for that ring?
Nov 18, 2009 at 12:38 AM
ishootsports3
p.1 #18 · Clear Filter = Soft Images ?
yes not shooting a filter is nice, but when you have your camera pulled into the ground it sure is nice to have a filter on that puppy
Nov 18, 2009 at 12:39 AM
Kaj E
p.1 #19 · Clear Filter = Soft Images ?
The use of a filter is particularly problematic on a long lens. The narrow field of view causes light rays reflected out of the camera/lens to be reflected straight back from the flat surface from the filter onto the lens elements and the sensor . This is most clearly seen on my 70-200 with a filter as lost contrast. And I use high quality multi-coated B&W filters.
Nov 18, 2009 at 12:54 AM
Two23
p.1 #20 · Clear Filter = Soft Images ?
Firmly agree with my simian friend above on this one. A few months ago I figured up the finanacial risk/benefit on so-called "protection" filters. I checked with two Nikon repair places and found that a front element replacement would run about $225. For me to put high quality (e.g. B+W) MC filters on my five most used lenses would run me close to $375 (B&H price.) Thus it would cost me more to buy the filters than it would to pay for a hypothetical repair. This made no sense to me at all. Like the monkey, I am almost totally an outdoor photographer, usually in harsh Dakota conditions. I don't routinely use filters; my lenses are all perfect. Modern Nikon coatings are very, very durable unlike Nikon's earlier ones. This is sort of like a religion: a strong belief based on faith and not evidence, so I'll leave it alone.
I'll will mention that on other forums in the past I've seen more complaints about Tiffen brand than any other. As with most things in photography, when you try to go cheap with optics, there can sometimes be a cost.
Kent in SD
Nov 18, 2009 at 01:40 AM
Two23
p.1 #21 · Clear Filter = Soft Images ?
That happened to my F100/Nikon 80-400mm VR once when a 70 mile an hour wind blew it right off the steep hillside I was working on. Lens landed "face" first. I had a Heliopan circ. polarizer on, but no lens cap. Some gravel went right through the filter and broken shards from the filter totally destroyed the front of my lens. My conclusion was that if I had the lens cap on, the lens would have been protected. If I had also had the lens hood on, it would have absorbed some of the blow. My final conclusion was that if I had no filter on at all, the element would still have been destroyed, but since it was on I ended up having to ALSO replace a $120 filter along with the repair. The cost to replace lens element was cheaper than the filter!
Kent in SD
Nov 18, 2009 at 01:45 AM
Elan II
p.1 #22 · Clear Filter = Soft Images ?
Yes, of course. Btw, what do you think Nikon makes all those NC filters for? They happened to come in all the same sizes as their lens filter threads.
And yes, this is my standard silly response for people saying filters don't belong on lenses. Nikon used to sell some lenses with external filters included at one time. The last one was the 45/2.8 P I believe. You're free to consider filters useless, or even evil if you like. But when it comes to optical formulas, neutral external filters have no effect since they are not an optic.
Nov 18, 2009 at 02:24 AM
ishootsports3
p.1 #23 · Clear Filter = Soft Images ?
Kent in SD
ouch, i was shooting biking in the woods and my buddy hit the jump and then comes over to look and whatcha know steps on the strap pulling the camera lense first into the ground, luckily he did not pull it hard and the ground was soft, i was very glad i had the filter on there to say the least
70-200 btw
Nov 18, 2009 at 02:30 AM
woodfin
p.1 #24 · Clear Filter = Soft Images ?
Sorry I am not sure how to upload images to this page. I have added a sample to my Flickr Site. It's a combined image cut from the two orig. images. The left was is without a filter, the right with the Tiffen "Ultra Clear" filter.
http://www.flickr.com/photos/woodfin/4113967580/
Nov 18, 2009 at 02:41 AM
Rodolfo Paiz
p.1 #25 · Clear Filter = Soft Images ?
Elan II wrote:
...neutral external filters have no effect since they are not an optic.
If you can see light that passes through it, or if it affects the light you see in any way, it's "optical". Neutral external filters are most definitely optics. Even the air-glass and glass-air edges have a role to play in optics.
Whoever told you that neutral filters are not optics?
Nov 18, 2009 at 03:07 AM
2 end
