sutegrat Offline Upload & Sell: Off
p.1 #8 · Shooting with Strobes Question | |
Shooting with strobes:
1) How are you going to trigger the strobes? In most cases the strobes are connected to a radio transmitter/receiver (PocketWiazrd) that you need to trigger. Having a PocketWizard on your camera on the same channel is a must.
2) Shoot in manual mode, and only single shot mode. You can't burst with strobes, unless they have super fast recycle times.
3) Do a custom white balance with the strobes.
4) If you're using a PocketWizard, set your camera to manual mode, and the shutter to 1/250. The light is controlled by the aperture, not the shutter.
5) Set your ISO to the lowest setting and change in combination with Aperture to nail the exposure.
6) Check your light coverage. Are you getting only half court/ice, 1/3rd or something different.
7) Don't stare at the strobes when you trigger them, they are bright.
8) If done right you won't want to shoot ambient again.
9) Knowing the equipment in the ceiling (strobes) will help with these types of questions and heopfully your expectations.
10) Go early to learn the setup and test, test, test...
-Paul
