Archive 2009 · The Raven
dmanky
p.1 #1 · The Raven
Taken today at the Vancouver Anthropology Museum - Wood Statue by Bill Reid
http://www.devman.ca/ImagesForDisplay/ravenstatue.jpg
C&C appreciated as I'm always learning!
Cheers.
Devin
Nov 16, 2009 at 01:52 AM
sbeme
p.1 #2 · The Raven
Interesting sculpture.
Two things.
1. Noise is very high. Was this under-exposed and then "re-covered" in processing? Because I see it was ISO 800 on a 5DMkII and I wouldnt expect that. Apply some noise reduction.
2. Never saw this sculpture, or the lighting on it, so I cant tell if the white balance is off.
Scott
Nov 16, 2009 at 07:46 AM
Dajavu
p.1 #3 · The Raven
Probably a lot to do with differing monitor calibrations, but I also see a lot of noise in the shadows, and would suggest darkening the bg a lot closer to black as well as reducing the noise in the shadowed areas of the statue. Good subject to capture, though!
Nov 16, 2009 at 12:48 PM
dmanky
p.1 #4 · The Raven
Hmmm I think the noise might be artifacts from post when I dialed down the blue channel since there were a couple faded pieces of blue fabric in the background. I'll give it a better go tonight after work and do the background properly.
Thanks for the comments! Couldn't see it on my monitor but it hasn't been calibrated properly yet.
Nov 16, 2009 at 01:39 PM
