Archive 2009 · How do you store lenses in a non-camera backpack?
xabi
p.1 #1 · How do you store lenses in a non-camera backpack?
I don't have a camera bag and I usually just carry my camera in my backpack. However, once in a while I would like to take a few more lenses for my hiking trip, mostly small primes (like 20mm, 50mm and 105mm primes). I would like to buy a small, padded bag with separate compartments to store my lenses, and just throw it in my backpack.
I don't seems to find this kind of bag for carrying small lenses inside a backpack. Do you have any suggestion? In general how do you store your lenses inside a backpack?
What I have been doing is just to store my lenses in my backpack together with my clothes and other stuffs, but I found that this way I usually have to pull everything out to find the lens I want. Is there a more organized solution for carrying small lenses for short trip?
Thanks
Nov 14, 2009 at 08:09 PM
p.1 #2 · How do you store lenses in a non-camera backpack?
I use Op/Tech Snoot Boots and LensCoat BodyGuards.
http://tinyurl.com/ykq7uz6
http://tinyurl.com/ylhk4uf
Nov 14, 2009 at 08:48 PM
ishootsports3
p.1 #3 · How do you store lenses in a non-camera backpack?
socks, drop each one of them in a sock and put the other sock over that little bundle. separate the lens bundles with clothing and your good to go for extra insurance but in no way needed
Nov 16, 2009 at 04:19 PM
kylegehmlich
p.1 #4 · How do you store lenses in a non-camera backpack?
Dakine makes a a couple camera bags that have removable inserts, which can also be bought separately. I use the insert from a Dakine Sequence when I want to carry a few lenses and a body in my regular backpack.
Nov 16, 2009 at 10:26 PM
xabi
p.1 #5 · How do you store lenses in a non-camera backpack?
Thanks for your responses so far!
Nov 16, 2009 at 10:28 PM
cherubino
p.1 #6 · How do you store lenses in a non-camera backpack?
What about foam soda can holders?
Cherubino
Nov 16, 2009 at 10:32 PM
skyvan
p.1 #7 · How do you store lenses in a non-camera backpack?
Kata makes a bag that has seperated compartments. It will fit a small body with 3 lenses, a computer and then there is space for some other stuff in a small compartment. Be warned it is a pretty small bag though but it was my first real camera bag and is very well made.
http://www.bhphotovideo.com/c/product/561687-REG/Kata_KT_DR_467_BR_DR_467_Digital_Rucksack_Black.html
80 bucks but comes with a $25 BH gift card making it effectively $55, a great deal.
Nov 18, 2009 at 07:13 AM
mpmendenhall
p.1 #8 · How do you store lenses in a non-camera backpack?
For hiking, I used to use thick wool socks or spare clothes in the pack. However, now I've switched to individual Lowepro lens cases for each lens (lots of 1M and 1S cases for the small lenses, 1N for medium ones) both for padding when tossed into a backpack and for easy access to the lenses when attached outside the pack (on the belt or loops on the shoulder straps). I like the Lowepro cases since they come in small sizes well suited to small older manual-focus primes.
Nov 18, 2009 at 10:46 AM
Dawud
p.1 #9 · How do you store lenses in a non-camera backpack?
are they much better then the pouches you get with the Canon L lenses ?
Nov 19, 2009 at 07:39 AM
p.1 #10 · How do you store lenses in a non-camera backpack?
Yes, I think they're better than the L pouches. The boots and guards are made from neoprene about 4mm thick that provides much better cushioning than the pouches. The boots have a strong clip on one side and a drawstring with a spring-loaded clamp on the other. I often clip a few snoot boots to the bottom parts of my backpack shoulder straps while traveling with smallish lenses. They hang out of the way while walking around, and you just have to reach down to grab them when you're changing lenses.
Nov 19, 2009 at 11:37 AM
Oasisbill
p.1 #11 · How do you store lenses in a non-camera backpack?
Wetsuit material, i.e. Stubbie holders (here in Australia), although they are one size for beer stubbies, but you can cut them up and insert to suit the size you need.... El cheapo solution.
Nov 19, 2009 at 11:55 AM
MountainTop
p.1 #12 · How do you store lenses in a non-camera backpack?
I like Lowepro cases. http://products.lowepro.com/catalog/Lens-Cases,11.htm
One for each lens; they're really well padded, and can be belt mounted if you want to (geeky). Their camera cases leave something to be desired, but I like this system for lenses.
Nov 22, 2009 at 08:07 AM
sav1977
p.1 #13 · How do you store lenses in a non-camera backpack?
Crown Royal whiskey. I use those purple pouches for several lenses, the G9...
Nov 22, 2009 at 08:14 AM
