Archive 2009 · alternative 24-70mm
anorphirith
p.1 #1 · alternative 24-70mm
I'm looking to buy a 24-70mm for weddings
I never tried a non canon lens before, and I'd like to give it a shot
so
Sigma ?
Tamron?
other ?
Nov 13, 2009 at 07:57 PM
Max10
p.1 #2 · alternative 24-70mm
Tamron 28-75, if you can get a good copy
Nov 13, 2009 at 09:54 PM
elader
p.1 #3 · alternative 24-70mm
Is someone paying you for the wedding? Buy the damn canon lens.
and then buy a back up camera body and two flashes.
Nov 13, 2009 at 10:22 PM
anorphirith
p.1 #4 · alternative 24-70mm
is there only one model ?
Nov 13, 2009 at 10:35 PM
RobertLynn
p.1 #5 · alternative 24-70mm
There is no competitor to the Canon 24-70.
The Tamron is slower to aquire focus in dim environments.
Nov 13, 2009 at 10:38 PM
Ian.Dobinson
p.1 #6 · alternative 24-70mm
The new Sigma 24-70 HSM could be a competitor for the canon but its not cheap compared to the Tamron (which optically is very good).
You could always look for the older 28-70L if you want more value for money.
Nov 14, 2009 at 12:30 AM
Beauchamp
p.1 #7 · alternative 24-70mm
So you've read.
Nov 14, 2009 at 12:44 AM
anorphirith
p.1 #8 · alternative 24-70mm
ok I'm getting the tamron
I'll buy canon when its coming with the 24-70 2.8 IS which is going to be very soon
Nov 14, 2009 at 12:57 AM
skibum5
p.1 #9 · alternative 24-70mm
so
Sigma ?
Tamron?
other ?
hmm you have FF, on APS-C the tamron is wonderfully sharp corner to corner if a bit lower in contrast on FF is does soften up at the edges even stopped all the way down unless the edges happen to be the distance away that matches the field curvature which almost never happens unless the subject is very far away like maybe even hundreds of feet away
the edges near 75mm on FF can get a nasty double image bokeh
anywhere at all near the center it is mad sharp though, the entire central 10MP or so will just be truly insanely sharp and free of CA then it will slowly tail off and then rapidly at the far borders and corners (sometimes that doesn't matter for weddings though) unless you have a very, very distant subject or one that happens to match the field curvature; but at least with the copies i tried even at the borders and corners it was noticeably sharper than the 24-105, if not at all sharp
i found it to be sharper than the 24-105 anywhere in the frame
it has very low levels of longitudinal CA/PF even at f/2.8 compared to others
focus is incredibly slow though, the slowest AF I have ever encountered
if you can live with the slow AF (fairly precise though) and a little bit lesser contrast it may make sense though as the similar canon zooms aren't really all that on a 5D2 so is 4x the price worth it if you still won't be getting all that anyway? depends on the AF, if you did indoor sports it would HAVE to be the canon, not sure about weddings.
maybe you could even pair a 24 II or 35L or f/2 with a 70-200 f/2.8? of course that setup costs a lot, but for serious wedding work that plus maybe even an 85 1.2 or 135 f/2 might be something....
the new sigma may be good, never touched it, read varying opinions, not sure what to make of it
there are building rumors of a new 24-70 IS, that might be the ticket, of course this lens has been 'almost here' for at least 5 years! this time though, for the first time ever, a somewhat reasonable source has mentioned it, so maybe this time it is real, see you in early 2010 anyway i would be shocked if that one did not turn out to be by far the best for this although one wonders about the price
Nov 14, 2009 at 01:27 AM
anorphirith
p.1 #10 · alternative 24-70mm
wow thanks for the interesting reply ! that tamron sounds more and more interesting !
I actually use a 5D2 + 17-40mm + 50mm f/1.4 + 200mm f/2 IS
so I'm really missing something between 24-70 ! for low light where focus may be a problem I can use the 200mm or the 50mm
do you have pictures of the strange bokeh and the dramatic loss of sharpness ? I'd like to see if the pictures would still be usable
thank you
Nov 14, 2009 at 03:10 AM
jaclarkaus
p.1 #11 · alternative 24-70mm
Bottom line - if you are getting paid, get the L.
Firstly, L gives great performance, perhaps at a price. The performance is remembered long after the price is forgotten.
Part of the $$$ you charge is the aura of being 'professional' - which is why it's bad form to use a P&S, despite them getting better, at least for good light situations.
If you don't use the L, then guests who are 'experts' (and with the explosion of DSLRs on the market, they are not uncommon) will consider whatever you use (except Zeiss, Leica, etc.) as 'not really professional' (regardless ofthe result) and it invariably impacts the overall result (now, I know it shouldn't, but it does)
Nov 14, 2009 at 03:58 AM
AlanGeli
p.1 #12 · alternative 24-70mm
I used the 24-70L with a 5D and a 1Ds3 and was disappointed, over all at the long end. The Tamron was not significantly better, so I moved to the Sigma 24-70 HSM and I was happy. It has not only excellent sharpness but also an incredible contrast.
Look at these reviews:
http://review.fengniao.com/123/1234847.html
http://review.fengniao.com/113/1134071.html
Nov 14, 2009 at 04:10 AM
saincteye
p.1 #13 · alternative 24-70mm
.......chinese reviews...lol ~~~ I was wondering why that thing looks familiar , but I think thers is also some kind of QC on sigma lenses ( at least for the 24-70 ) that unless you get a sharp copy , otherwise it;s not really that good .
Nov 14, 2009 at 05:43 AM
hauxon
p.1 #14 · alternative 24-70mm
I'd say the best alternative to 24-70L is 24-105L IS.
Nov 14, 2009 at 06:18 AM
jrscls
p.1 #15 · alternative 24-70mm
My alternative to the 24-70 is the 24-105 f4 IS and 35 f1.4 L combo.
Nov 14, 2009 at 07:31 AM
BubbaJon
p.1 #16 · alternative 24-70mm
Beauchamp wrote:
So you've read.
So I have experienced. It is slower - no doubt about it. And it hunts. But oh my - razor sharp and the color and contrast are IMHO almost as good as the 24-70L. It weighs a LOT less and is a fraction of the price. I have used it successfully at weddings but I have had a couple of occasions where worrying about focus made me wish for the 24-70 - I hate worrying at weddings!
Nov 14, 2009 at 09:15 AM
RobertLynn
p.1 #17 · alternative 24-70mm
Beauchamp wrote:
So you've read.
I've read? Or maybe so I've experienced. I have access to a Tamron 28-75 with a clown at work. I've given suggested this lens a number of times, but when focus speed is king, I'm going for the Canon.
Nov 14, 2009 at 10:04 AM
RobertLynn
p.1 #18 · alternative 24-70mm
Did Canon tell you it's going to be very soon? For over two years, people have been saying yesterday. I wouldn't hold your breath.
anorphirith
p.1 #19 · alternative 24-70mm
well I don't take chances
Nov 14, 2009 at 01:36 PM
anorphirith
p.1 #20 · alternative 24-70mm
I'm sure that with my 200mm f/2 IS nobody will doubt of my "aura"
Nov 14, 2009 at 01:38 PM
