LordV Offline Dedicated FM Upload & Sell: Off
p.1 #12 · Confused on how to get to 2:1 or Better | |
friscoron wrote:
Thanks for your responses, guys! Like you mentioned, Bruce, I'm trying to assimmilate a plan to get the equipment I need to start doing some macro. It's really exciting to me to see the fabulous macro shots you guys are posting. I know I have a lot to learn, it's going to be a fun process, and I'm looking forward to getting started.
Another question. When you reverse a lens, does that mean you reverse the 50 mm lens, then attach your macro? Or do you shoot simply through the reversed lens?
Ron
The easiest reversed lens to use is one reversed onto another lens ( a shorter lens onto a longer lens) the reversed lens acts like an add on dioptre lens and is normally used wide open and focused on infinity, focus and aperture are still controlled by the main lens although the total focus range is pretty limited. So the 50mm lens is reversed onto the macro lens which is attached to the camera body.
You can reverse a shortish lens (normally 30 to 50mm) directly onto the camera body. This can give upto about 3:1 magnification but is much harder to use as you have to preset the aperture so is actually easier with an old manual lens.
Brian v.
