       2       3       4       5       end
Archive 2009 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Will Patterson
p.1 #1 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
** edit 11/17/09 ** - Sent lens to Midstate last week, it is currently apart on their bench and they are looking for loose elements. Will call me back tomorrow with an estimate.
** edit 11/22/09 ** - Discovered my problem -
** edit 12/07/09 ** - Received the lens back from Midstate again, Mark found and fixed the problem :-) Updated focus pics tonight..
I'm semi-regretting getting this lens, it's a Mark 1, works perfectly, minor cosmetic issues, but after I did some shots in the field I took it home and it doesn't appear to be sharp. I spoke with MidState Camera repair and they said they'd look at it, should I send it in? It seems as though there is a haze on the photos. The optics are clean, they look fantastic for a lens that's over a decade old.
All shot with the center point focus, ones of the tape measure and paper are done with MF.
Two of the duck (one a 100% crop), then a 100% crop of a van.
Edited on Dec 07, 2009 at 09:37 AM · View previous versions
Nov 10, 2009 at 06:02 PM
Chris Wynne
p.1 #2 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Nov 10, 2009 at 06:27 PM
M Vers
p.1 #3 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Wow, that's pretty poor performance from a lens of this caliber. Did you have a deal with the seller before you bought it...i.e. return policy?
Nov 10, 2009 at 06:30 PM
Will Patterson
p.1 #4 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Nope.. not gonna even worry about that. I'm just making sure I'm right in saying I should send it in, possibly to midstate camera repair. I can't find that list I saw on here lately of camera repair centers that work on Canon SLR equipment.
Nov 10, 2009 at 06:33 PM
M Vers
p.1 #5 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Well, the problem is definitely there--you're not seeing things. Hope everything works out.
Nov 10, 2009 at 06:36 PM
philbinley
[X]
p.1 #6 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Send that puppy in !!!
Bill
Nov 10, 2009 at 06:38 PM
joezasada
p.1 #7 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
assuming you are set to centre focus point, one-shot AF, with AF expansion off...
I'de say indeed you need to have that beastie calibrated...
Nov 10, 2009 at 06:44 PM
PetKal
p.1 #8 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
That's too bad....what you seem to be getting is a $500 Vivitar or Opteka telephoto image quality, perhaps not even that.
What's the situation when you stop her down ?
Nov 10, 2009 at 06:45 PM
meechahel
p.1 #9 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Will, if this is the same lens that I had, I suggest getting it looked at. The 100% crops from my photos were much sharper (for the most part).
Nov 10, 2009 at 07:08 PM
Will Patterson
p.1 #10 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Yea it's the same lens And I've tried a variety of shots, but even on the lame 1D2n's rear LCD I can tell none are sharp no matter what I do.
Nov 10, 2009 at 07:15 PM
Will Patterson
p.1 #11 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
So I need to send it in somewhere. Can someone recommend a particular repair center? I've spoken on the phone with someone at midstate camera in Rhode Island who said he would look at it, but it sounded like a very small operation (he and his brother ARE mid-state camera repair).
Nov 10, 2009 at 07:17 PM
Daniel Bates
p.1 #12 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Midstate was very highly recommended by everyone I polled when I needed to send a 300/2.8 in for service. They were very professional about the job, as well, and they have had my business ever since.
Here are the aggregate SportsShooter results if you care to peruse their opinions.
Nov 10, 2009 at 07:29 PM
Andrew J
p.1 #13 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Midstate cleaned and calibrated mine. It wasn't that bad.
In sunlight I believe you'll see a haze on the elemets and they'll remove that.
Nov 10, 2009 at 07:37 PM
Will Patterson
p.1 #14 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Thanks Daniel and Andrew. Looks like I'll box it up and ship it out to them tomorrow.
Nov 10, 2009 at 07:44 PM
Daniel Bates
p.1 #15 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Like everyone said previously, that's not what right looks like.
Hopefully you'll get it back soon, as sharp as a 400/2.8L should be!
Nov 10, 2009 at 07:49 PM
Scott Sewell
p.1 #16 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Will, no offense, but I'm gonna go out on a limb here and question your testing procedure. Your shutter speeds on many of these are super slow for such a long lens. Even if you were on a tripod...1/10, 1/25, 1/60...man, those are some slow shutter speeds.
Anyway, I had a Mk1 and it was a sharp lens. I sent mine into CRIS Camera in Arizona before I sold it and they gave it a clean bill of health. Great to deal with and very prompt service.
Good luck.
Nov 10, 2009 at 08:05 PM
corndog
p.1 #17 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Definitely get out and try some fast shutter speeds. Still, it looks hazy and just weird. Does that bokeh in number one look normal? Looks funky to me.
Was this your lens?
Nov 10, 2009 at 08:54 PM
Will Patterson
p.1 #18 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
I was shooting between 1/800th and 1/3200th shutter speed when I was outside, and they all look like this. Most were actually shot from a monopod, some were shot while I was in my car shooting out my window. There were even some at 1/8000th when I accidentally had the ISO set a little high and they also look blurry/bad.
And hahaha NO, that wasn't my lens. I've seen that video before, cracks me up. The lens actually arrived VERY well packed inside a 400 2.8 IS case, then packed very well inside a large box. Overall the package weighed 35 lbs!
Nov 10, 2009 at 09:00 PM
vince
p.1 #19 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
Yeah this lens looks really bad, maybe it was dropped or bashed around earlier and the glass got misaligned? Even my cheap sigma 70-300 APO gave me sharper shots wide open. Send it in.
Nov 11, 2009 at 02:52 AM
RobAmy
p.1 #20 · 400 2.8 Mk 1 - NOT sharp - FIXED!!
I had work done at mid state as I live in RI, excellent service. They are small but they are good.
Nov 11, 2009 at 05:42 AM
       2       3       4       5       end
       2       3       4       5       end
