       2       3       4       5       end
Archive 2009 · Good general L lens
Jeff Fletcher
p.1 #1 · Good general L lens
I will be buying the canon 50d, and since i sold all my camera lens (need it the money at the time),and I don't have a lot of money to spend.I can only get 1 lens,I will be shooting the following, outside construction photo's and landscape, some flowers and birds.Inside picture of my daughter and son. I had L lens and that's what I want. But only 1 for now, in few years hopefully i can buy more. I was thinking, 17-40L, 24- 70L, or 135L. Thanks for your answers
Nov 10, 2009 at 12:18 PM
John--G
p.1 #2 · Good general L lens
The 24-105L would probably be your best choice.
Nov 10, 2009 at 12:50 PM
MaxiKana
p.1 #3 · Good general L lens
24-70L
Nov 10, 2009 at 12:52 PM
tazzz78
p.1 #4 · Good general L lens
Based on your requirements on a crop camera I think only 17-40 fits your bill, apart from much more expensive 16-35. I think you would find 24 not wide enough for shots inside and outside building shots, but that depends on your shooting style. When I used to have a crop camera I have chosen 17-40 as the first L lens due to it's price and range. Never looked back.
Edit: forgot about birds and flowers- 24-105 would probably be better than.
jboucher50
p.1 #5 · Good general L lens
Another option would be to look for a used 28-70 2.8L. Superb L quality and less expensive than a 24-70.
Nov 10, 2009 at 12:57 PM
Guest
Guest
p.1 #6 · Good general L lens
1200mm 5.6L
Nov 10, 2009 at 12:58 PM
markymarc
p.1 #7 · Good general L lens
I would choose between the 24-70 or the 24-105.
Nov 10, 2009 at 01:03 PM
J Andersen
p.1 #8 · Good general L lens
MaxiKana wrote:
24-70L
+1
Excellent all round lens. It has near macro capabilities and an effective shallow DOF at 2.8
Nov 10, 2009 at 01:05 PM
Aberdeen Photo
p.1 #9 · Good general L lens
35l; always a good answer
Nov 10, 2009 at 01:06 PM
helimat
p.1 #10 · Good general L lens
24-70L
Nov 10, 2009 at 01:07 PM
Steve Spencer
p.1 #11 · Good general L lens
To me this just isn't a one lens solution. Construction and landscape sounds like you want some wide angle coverage. Flowers you probably want something that can shoot fairly close up. Birds you will need something with a fair amount of reach and taking pictures of your kids indoors you will probably want a fast aperture. From the options it would seem you have about $1,000 to spend. I would spread that across at least two lenses. If you have to get an L, the 17-40L would work reasonably well for your construction and landscape shots, and is less expensive allowing you to buy a second lens. A 50mm f/1.4 would work reasonably well for indoor shots of your kids and with extension tubes could do flowers pretty well too. With your budget you will have to add a lens for birds later. I hope this helps.
Nov 10, 2009 at 01:20 PM
Jeff Fletcher
p.1 #12 · Good general L lens
Thanks for all your replies so, far.
Nov 10, 2009 at 02:02 PM
TehKimchi
p.1 #13 · Good general L lens
24-70L for flexibility
Anywhere, anytime.
Nov 10, 2009 at 02:09 PM
rhorta
p.1 #14 · Good general L lens
+1
GP zoom 24-70/2.8
Ruy
Nov 10, 2009 at 02:25 PM
alexandre
p.1 #15 · Good general L lens
24-70, period
Nov 10, 2009 at 02:44 PM
Scott Snyder
p.1 #16 · Good general L lens
If I was limited to the price of one new L, I'd give up on the L and investigate some of the fine non-L options. For the 1,300ish price of one new 24-70 you could pick up a nice used kit off the b&s here. Say a Tokina 12-24, Sigma 50 1.4, Canon 85 1.8 with several hundred left over. Oops that sounds like what's in my bag.
Nov 10, 2009 at 02:56 PM
kakomu
p.1 #17 · Good general L lens
Indeed. Limiting your selection to L lenses with a low budget is, well, limiting.
Consider the Tamron 17-50 f/2.8 plus a longer prime, maybe.
Nov 10, 2009 at 03:07 PM
M Vers
p.1 #18 · Good general L lens
On the 50D? 17-55IS. You don't need an L lens to get L results.
paulfeng
p.1 #19 · Good general L lens
Another non-L to consider is the new 15-85, perhaps pending further reviews/reports/price drops.
Nov 10, 2009 at 03:16 PM
kakomu
p.1 #20 · Good general L lens
You might also want to consider the 35 f/2 or 28 f/2.8 and the 70-200 F/4L. You have a good low-light wide angle and a decently long telephoto zoom for birds.
Nov 10, 2009 at 03:23 PM
       2       3       4       5       end
       2       3       4       5       end
