FM Actions & Plugins support
Workflow Guidelines
Archive 2009 · Epson color issue
J4644
p.1 #1 · Epson color issue
Hi everyone,
I have an Epson 3800 printer. Just processed an image and it looked good on my monitor. Soft-proof also looked good. Went to print and I have a red cast in all of the blue colors on the print. I have never seen this before. I assume it is the printer. Anyone know what is going on here?
Thanks,
Jim
Nov 09, 2009 at 10:26 PM
colinm
p.1 #2 · Epson color issue
If the cast is just in the blues and not over the entire image, run a nozzle check and then run cleanings until it comes back absolutely pristine. (If it's difficult to decipher, you can also just run an automatic nozzle check.)
If there's an overall magenta cast to the image, the error is likely in your combination of software and driver settings.
Nov 09, 2009 at 11:24 PM
J4644
p.1 #3 · Epson color issue
Hi Colin,
Just the blues are affected. I guess I will need to see if a nozzle is clogged.
Thank you, I will let you know.
Jim
Nov 10, 2009 at 12:00 AM
tomb18
p.1 #4 · Epson color issue
I had a red cast over many prints when my ink was expired on a R1800. Replacing the red cartridge always fixed it for me.
Can't say if it's your issue, but if cleaning can't fix it, then you might check the age of the inks.
Nov 10, 2009 at 12:26 AM
J4644
p.1 #5 · Epson color issue
Colin,
Fantastic diagnosis and treatment was successful. Thank you very much.
Jim
Nov 10, 2009 at 12:28 AM
Peter Figen
p.1 #6 · Epson color issue
The very first thing I do every time I go to make prints is to run a nozzle check before I do anything else, and again several times during a day of printing. That will save many hours of aggravation and wasted materials.
Nov 10, 2009 at 04:38 AM
pjbishop
p.1 #7 · Epson color issue
That is excellent advice, Peter! Especially when printing on larger paper.
Nov 10, 2009 at 12:05 PM
J4644
p.1 #8 · Epson color issue
Thanks tomb18,
I will keep that in mind next time.
Jim
Nov 10, 2009 at 12:21 PM
J4644
p.1 #9 · Epson color issue
Peter,
Thanks. You are probably right to approach it that way. It is funny how quickly it occurs. Print before showed no signs of a problem. Then, next print full blown problem.
Jim
Nov 10, 2009 at 12:23 PM
J4644
p.1 #10 · Epson color issue
Colin,
The nozzle check indicated broken up ( gaps ) on the blue wavy test print. Can I assume that blue was not able to spray enough of it's color and another color overwhelmed it? If so, why was that color red? It seems to me that this could be a further diagnostic tool. Example, not enough blue and too much red equals clogged blue jets.
Thanks,
Jim
Nov 10, 2009 at 12:28 PM
Peter Figen
p.1 #11 · Epson color issue
It probably depends on exactly which nozzles are clogged in combination with the specific color being printed as to how it shows in your print, but what I see if even a single Cyan nozzle is clogged will be banding in a blue sky.
Nov 10, 2009 at 03:38 PM
HerbChong
p.1 #12 · Epson color issue
clogged nozzle means banding. you should have been able to see that no matter what colors are banding.
Herb..
Nov 10, 2009 at 08:29 PM
