Archive 2009 · Big PLM with a speedlight?
Jim Quinn
p.1 #1 · Big PLM with a speedlight?
Hi,
Various threads on this forum have discussed the characteristics and applications of Paul Buff's PLM umbrellas with White Lightning or Alien Bees monolights or lights from other manufacturers. It seems that one of the main reasons for choosing the silver PLMs, in particular, is that they will throw out a lot of light from a relatively low-powered light source, permitting the use of less powerful flashes, lower flash settings (allowing quicker recycle times), and greater subject-to-light distances.
Some posters have asked whether speedlights could be used successfully with these modifiers. Because speedlights aren't designed to operate as bare-bulb light sources (unlike WL/AB monilights, for example), they wouldn't fill the umbrellas with light, making the PLMs less efficient and even than if they were fitted with bare-bulb light heads.
Thanks to David Hobby and his Strobist blog, and to shooters like Joe McNally who use small flashes so successfully, lots of photographers are now relying heavily on speedlights for many lighting jobs that may have required larger lights in the past. And that raises a question:
Since a silver PLM maximizes output from its light source, would a speedlight fitted with a StoFen dome (or a similar dome diffuser) spread the light widely enough to get most of the benefits of these big umbrellas? If that combination works, it would make a lightweight and very portable location lighting tool.
Jim Quinn
Nov 09, 2009 at 02:06 AM
sbv20
p.1 #2 · Big PLM with a speedlight?
I use a Sigma 500DG super and own the medium-sized PLM. I did a decent amount of testing and specifically compared the light pattern at each of the flash's zoom settings, as well as with the omnibounce. I found the ideal setting to be flipping down the on-flash diffuser which brings it to a 17mm zoom. The output was a little higher than with the omnibounce and the spread was about similar. Based on a direct comparison I chose to use it without the omnibounce.
Nov 09, 2009 at 03:30 AM
DrewChilly
p.1 #3 · Big PLM with a speedlight?
All in all, how would you rate your experience using the PLM with your speedlights?
Nov 09, 2009 at 05:14 AM
sbv20
p.1 #4 · Big PLM with a speedlight?
All in all, I'm happy with the purchase. I don't have a monolight to compare to the speedlight, however. I don't mind the crude setup (gaff tape to a speedlight foot to get it closer to the umbrella axis) because I'm just an amateur not trying to look like a pro. I'm still working on understanding how to use the quality of light, and look forward to my front diffuser coming in this week, but that's another issue.
Nov 09, 2009 at 04:15 PM
