Archive 2009 · Calculator for Timelapse
nolanthomas
p.1 #1 · Calculator for Timelapse
I have been trying to use my TI-84 calculator to do time lapse videos. I have tried a number of programs in the calculator, but none of them make the camera fire. I am using a Rebel XSi. Has anyone had any luck using an XSi? I would really, really appreciate any help. Thanks.
Nov 08, 2009 at 01:34 AM
cgardner
p.1 #2 · Calculator for Timelapse
Have you seen this tutorial?
http://www.instructables.com/id/Turn-a-TI-Graphing-Calculator-into-an-Intervalomet/
Nov 08, 2009 at 01:44 AM
nolanthomas
p.1 #3 · Calculator for Timelapse
Ya, that's where I discovered that this was possible. I've used the code on that site and a couple different codes, but I haven't had any success. I was wondering if maybe I needed to change a certain setting in my camera or something like that. The program runs on the calculator, but the shutter doesn't fire.
Nov 08, 2009 at 01:47 AM
cgardner
p.1 #4 · Calculator for Timelapse
In that tutorial the camera used had a remote shutter cord that used a mini-plug. Is that the case on your camera? If not the problem might be an incorrect pinout / connection to the camera remote release socket.
When all else fails just beat your head against the camera -- in regular intervals
Chuck
Nov 08, 2009 at 02:44 AM
jerrykur
p.1 #5 · Calculator for Timelapse
It looks like there an intervalometer available for the XSi. I use one with my 5DMk2 to take star track shots and such. I got mine from eBay for $40 or so.
Nov 08, 2009 at 03:04 AM
nolanthomas
p.1 #6 · Calculator for Timelapse
I'm using a 2.5 mm to 2.5mm audio cable. It fits in both ends and I thought it would work, but maybe i do need a different cord. Has anyone had any luck with this calculator thing.
Nov 08, 2009 at 04:20 AM
jkashinsky
p.1 #7 · Calculator for Timelapse
If it worked for the author, I think that it was a fluke.
Both focus and shutter require a contact closure to the common.
I believe that the output from the calculator is audio which is used for sending data between two calculators.
The audio out is not the same as a contact closure.
Nov 08, 2009 at 09:45 PM
Me_XMan
p.1 #8 · Calculator for Timelapse
Why you must suffer? Get one on Ebay for $20 and save you a lot of time.
Nov 09, 2009 at 01:48 AM
