garyvot Offline Buy and Sell: On
p.1 #25 · My EOS 7D review published! | |
Nice review Roland. I noted this:
The 5D Mark II images looked significantly sharper with better local contrast at all ISO. In theory, there should not be a great difference in perceived resolution between the 18MP sensor of the 7D and 21.1 MP sensor of the 5D Mark II. I do not know why the 5D Mark II images look sharper, but if I were to guess, I think maybe the 5D Mark II has a significantly weaker anti-aliasing filter than the 7D and that could be the reason why the 5D Mark II images looked sharper.
There are a couple of things I've observed in my own testing: If using DPP, at the default settings some NR is applied to 7D files even at ISO 100. This is not the case for 5D2 files. However, I think this only accounts for part of the difference.
The other factor seems to be RAW conversion algorithms. For some reaosn, Capture One Pro 5 seems to produce significantly sharper output from the 7D, with better micro-contrast, at low ISO than DPP with all NR disabled. See alundeb's comment above; there is also some discussion of this on this thread: http://www.fredmiranda.com/forum/topic/829160/0?keyword=capture,one#7700355
Based on this I'd certainly recommend that all 7D owners at least take a look at the the Capture One 5 trial.
