FM Actions & Plugins support
Workflow Guidelines
Archive 2009 · CS4 x64 problem.
yorkie
p.1 #1 · CS4 x64 problem.
I've just installed Photoshop CS4, both 32 and 64 bit versions, on a PC running Windows 7 64bit.
My problem is with the x64 version which doesn't show guides when any tool ( eg crop, pen, ruler, lasso etc etc) is used until the mouse key is released. For example, using the lasso tool the path being traced doesn't show until the left mouse key is released.
The x86 version works properly and I've made sure all preferences are the same in both versions.
Am I missing something blindingly obvious (probably!!) or have others had the same problem?
Regards
Keith
Nov 05, 2009 at 06:22 PM
yorkie
p.1 #2 · CS4 x64 problem.
Update:-
Disabled OpenGL Drawing and now tools work as advertised.
Strange that the same problem doesn't affect the 32bit version.
Nov 06, 2009 at 11:17 AM
AdrianRogers
p.1 #3 · CS4 x64 problem.
I would suggest fully updating Photoshop and your graphics drivers, see if OpenGL drawing works correctly then
Nov 06, 2009 at 02:30 PM
yorkie
p.1 #4 · CS4 x64 problem.
After lots of Googling I've discovered quite a few people reporting problems with the latest NVIDIA 64 bit driver, although not specifically related to Photoshop.
So that's probably the culprit.
Nov 06, 2009 at 04:04 PM
