Archive 2009 · Zeiss 60mm s-planar on 5D
rachp
p.1 #1 · Zeiss 60mm s-planar on 5D
I just picked up a Zeiss 60mm s-planar and it will not fit on my 5D2. I won't shave the 5D2 so I need to find out what I can do to the lens.
There are two levers on the rear that stick out past everything else quite a bit. I really don't think a thicker adapter will move them far enough away but I will try that later today.
Does it have to have a leverectomy? There are two areas - the ap lever and a fixed post - is this usually what needs to be trimmed down?
Has anyone else had issues with this lens and a 5D/2?
Thanks for any help!
Nov 04, 2009 at 01:22 PM
Tariq Gibran
p.1 #2 · Zeiss 60mm s-planar on 5D
Can you post a picture of the rear of the lens mount? It may be that there is a small, removable, semi-circular piece that is causing the problem. That is what often causes issues mounting some of the 35-70's until it's easily removed. Not sure if it is on your 60 though.
Nov 04, 2009 at 01:35 PM
jjlphoto
[X]
p.1 #3 · Zeiss 60mm s-planar on 5D
I believe this lens has the 'shark fin' that protrudes a bit too far. Gentle grinding with a file or Dremmel will do the trick.
Nov 04, 2009 at 01:51 PM
Tariq Gibran
p.1 #4 · Zeiss 60mm s-planar on 5D
First picture, left side of lens and just above flush with the rear element, I think that is the piece that needs to be removed. See if you notice a small screw that attaches it.
Nov 04, 2009 at 01:52 PM
Tariq Gibran
p.1 #5 · Zeiss 60mm s-planar on 5D
If you don't, then it may be another issue such as jjlphoto mentioned. I have not used this particular lens before.
Nov 04, 2009 at 01:56 PM
rachp
p.1 #6 · Zeiss 60mm s-planar on 5D
"shark fin" - that is it! The ap lever is very near the same height - should I file it down, too?
Any tips on the best way to cover up the rear element for protection? I think I remember painters tape?
Thanks!
rachp
p.1 #7 · Zeiss 60mm s-planar on 5D
I don't see a screw and that area seems to be made into the same part of the base as the ap lever.
Nov 04, 2009 at 01:58 PM
rachp
p.1 #8 · Zeiss 60mm s-planar on 5D
Thanks for the input. I think that the area you pointed out may need to be trimmed off as well.
Nov 04, 2009 at 01:59 PM
Tariq Gibran
p.1 #9 · Zeiss 60mm s-planar on 5D
Hmm. Sorry. You might want to wait for others to chime in before you start cutting just to be safe.
Nov 04, 2009 at 02:01 PM
gasrocks
p.1 #10 · Zeiss 60mm s-planar on 5D
I have done such things and just used some tissue stuffed down inside the rear of the lens and covered a couple layers of masking tape.
Nov 04, 2009 at 02:40 PM
rachp
p.1 #11 · Zeiss 60mm s-planar on 5D
Thanks gasrocks. I may give the tissue paper a try so I don't have to make a special trip to the hardware store.
Nov 04, 2009 at 03:13 PM
AhamB
p.1 #12 · Zeiss 60mm s-planar on 5D
It might be wise to put something a harder on top of the tissue (and under the masking tape) - something that can take an impact and protect the rear lens element. Just in case. I've heard about people destroying their rear elements in operations like this, so better to take every precaution.
Nov 04, 2009 at 03:31 PM
rachp
p.1 #13 · Zeiss 60mm s-planar on 5D
Good thinking, AhamB! One little slip and the tape would be history and you would be right down to the lens.....
Nov 04, 2009 at 03:44 PM
kosmoskatten
p.1 #14 · Zeiss 60mm s-planar on 5D
Rachp: great find, I love my 60 - though now I use it on Sony.
Masking tape and a little hard hat (stripped from a plastic single use cup) with a soft cloth underneath will protect the lens.
When filing down the sharkfin: place the lens tipped over on it's side with the fin out to the side and on something that will not cause it to slip away from you. File away from the top of the fin and outward, away from the lens. This way you will have the least amount of file debris entering the lens. You can also easily gauge the progress when it is lying on the side.
I used a Dremel and a vacuum cleaner so my filing down was a swift affair but whatever floats your boat. On another lens I did not bother with the dremel as the metal is quite soft and requires little effort to file down so I used a small but wide metal file.
A piece of sanding paper - or a nail file - to round off any sharp edge remaining and you are good to go.
Nov 04, 2009 at 04:54 PM
rachp
p.1 #15 · Zeiss 60mm s-planar on 5D
Thanks for the details, kosmoskatten!! Just the things I need to know to ease the fear a bit I am going to give it a go tonight and maybe I will have some test shots tomorrow.....
Nov 04, 2009 at 04:58 PM
kosmoskatten
p.1 #16 · Zeiss 60mm s-planar on 5D
Look forward to it - keep 'em coming. / Henrik
Nov 04, 2009 at 05:15 PM
Jim Schemel
p.1 #17 · Zeiss 60mm s-planar on 5D
Rachel,
i just checked my 60mm Planar and it does not have either of the protrusions.Maybe someone shaved them off before i got it or its a different lens.Is yours made in Japan or West Germany? Mine is made in West Germany.Hope it goes well.It is well worth the effort
-Jim
Nov 04, 2009 at 05:37 PM
rachp
p.1 #18 · Zeiss 60mm s-planar on 5D
Hey Jim. Mine is West Germany. I have an XSi that I can play with until it goes in for surgery Very excited to give it a go - Thanks again for the recommendation!
Nov 04, 2009 at 05:43 PM
lovinglife
p.1 #19 · Zeiss 60mm s-planar on 5D
I didnt the same thing on my Nikon AI 50mm lens.
(1) Take some saran wrap and wrap around the lens.
(2) stick the protruding piece thru the saran wrap
(3) take a filer and file down, its not that hard....
Its not really noticeable, and doesnt look bad at the end.
Nov 04, 2009 at 05:57 PM
rachp
p.1 #20 · Zeiss 60mm s-planar on 5D
Saran wrap is a great idea! I will be starting on it in a few minutes...
Nov 04, 2009 at 07:36 PM
