derry1 Offline Image Upload: On
p.1 #2 · D-Lighting all the time? | |
have never liked it on all the time,,
on some deep shadow shots the d-lighting did good, and some slightly brighter shots I did not like it on,, I have used in dim gyms covering volleyball and it worked fine,,
since I use NX2 it is ease to apply and see how it can help and if I like run it as a part of the batch processing,,
you can also take a photo and then apply D-lighting to that photo in-camera and compare before firing away,, display your photo on the camera screen and press the OK button,, d-lighting menu will be at the top,, select and go from there,,
Derry
