FM Forums | Alternative Gear & Lenses | Join Image Upload
Help: 18mm or 21mm Carl Zeiss EF Go to previous topic Go to next topic
bobring
Buy and Sell: On
p.1 #1 · Help: 18mm or 21mm Carl Zeiss EF
Looking for opinions. I've scoured and read all of the posts here and am still torn as to which lens to get. I looked at my history and my 17-40 Canon zoom comes up a lot at 17mm. But, I've always wanted the 21mm. I want a lens that I can use for architectural & landscape photography (min curving lines > flat field right?) and has the Zeiss 3D look! Will use it on a Canon 1DsIII. Thoughts? Opinions? Thanks, Bob.
Nov 01, 2009 at 02:26 PM
jjlphoto
Image Upload: On
p.1 #2 · Help: 18mm or 21mm Carl Zeiss EF
If 17mm is your preferred focal length, there are two ways to go:
Contax 17~35N (converted by Conurus) Runs fully auto focus and exposure, just like a Canon lens.
Nikkor 14~24G (with a 16:9 adapter) Manual focus, you must stop down the aperture to make the exposure.
I own both a 17~35N and a CY 21/2.8
Nov 01, 2009 at 02:43 PM
Lotusm50
Image Upload: Off
p.1 #3 · Help: 18mm or 21mm Carl Zeiss EF
I don't know about the ZE 21 for architecture. As good as it is, the moustache distortion may be a bit of a challenge in that application.
The ZE 18 might have better distortion characteristics -- that is easier to fix -- than the 21, but it won't as sharp, notably in the corners.
The Contax 17~35N (converted by Conurus) and Nikkor 14~24G (with a 16:9 adapter) are options that are quite a bit larger in size, with a bit of added flexibility due to zoom. The Nikkor while sharp (probably sharper than the ZE 18), lacks that ol' Zeiss magic and can't take filters. The Contax N zoom is probably better than the ZE 18 wide open, and as sharp in the center wide open as the ZE 21 (if not more so) but less so toward the edges. It's also twice the cost of the ZE 18, if you can find one, but has Zeiss-ness in spades. I hope this helps a little.
I have both a 17-35N and the ZF 18.
Nov 01, 2009 at 03:17 PM
mawz
Image Upload: Off
p.1 #4 · Help: 18mm or 21mm Carl Zeiss EF
Distortion characteristics are apparently near-identical between the 18 and 21.
Nov 01, 2009 at 03:22 PM
alexandre
Buy and Sell: On
p.1 #5 · Help: 18mm or 21mm Carl Zeiss EF
Not a Zeiss, but I'd try a WA shift lens, like Canon or Olympus.
Nov 01, 2009 at 03:29 PM
ICQ
mMontag
Image Upload: Off
p.1 #6 · Help: 18mm or 21mm Carl Zeiss EF
For Architectural it's the 17 &/or 24II TS-E - hands down - shift to correct vertical lines - minimal distortion. Both are great for landscape - the 24 is easier to filter.
The 21mm Zeiss certainly has a great IQ - but also has a very prominent distortion if your using it for Architectural.
jjlphoto - how does the 17-35 compare to the 21mm? - the copy I have is very strong in the 17 to 21 range. I've only shot landscape & nature with that lens - don't know about distortion related to Architectural. Much less distortion & better edge / corner IQ than the 17-40.
Nov 01, 2009 at 03:41 PM
Lotusm50
Image Upload: Off
p.1 #7 · Help: 18mm or 21mm Carl Zeiss EF
and
Of course, neither of these options will give the OP the unique Zeiss qualities and 3-D characteristics that the Zeiss lenses will provide. I look of images from Canon lenses (whether sharp or not), IMHO, always fail to impress. I woulkd really like to see Zeiss, or Cosina or Schnieder produce a tilt-shift lens or two in this focal range. Of course, you could always use one of the exceptional Schnieder or Rodenstock digital view camera lenses on a view camera attachment for your DSLR -- if you must have good T-S capability.
Nov 01, 2009 at 04:14 PM
mMontag
Image Upload: Off
p.1 #8 · Help: 18mm or 21mm Carl Zeiss EF
The two Canon lenses that I currently own & witness Zeiss like rendering is the Canon 24II TS-E & 70-200/4 at the short end. Rich, rich color, micro-contrast and - CAREFUL - 3d look & feel. JMO.
I'm using the 24II to anchor my landscape and interior Architectural kit - I find it more versatile than the 21mm Zeiss - easy shift pano's if 24 is not wide enough - add a 1.4 TC to go longer - minimal distortion even at close distance.
Maybe the 24mm is too narrow for the requested purpose - that takes it back to the 17-35N or the 18ZE - if Zeissness and wide are the key ingredients.
Lotusm50 - Do you know if the distortion in the 21 can be improved with DxO or other software?
Nov 01, 2009 at 06:25 PM
bobring
Buy and Sell: On
p.1 #9 · Help: 18mm or 21mm Carl Zeiss EF
Great feedback. I guess I'm mistaken in that I thought the 18 & 21 would provide straight lines (flat field) so to speak if used properly for interiors. However, major use for me is for landscape. I have the old Canon 24mm TSE (orig) and it's ok but wanted something wider with as mMontag says " Zeisness and wide are key ingredients". The 17-35 is expensive if converted (seeing it here for ~$3K). Hmmmm, still not sure!
Nov 01, 2009 at 09:59 PM
mawz
Image Upload: Off
p.1 #10 · Help: 18mm or 21mm Carl Zeiss EF
Flat field means that the lens is focused at the same distance across the frame, a lens with curvature of field will have the corners focused at a different distance than the centre.
Distortion is a separate issue, lenses with strong curvature of field may have minimal distortion (which is common in fast 50mm's)
Nov 01, 2009 at 10:39 PM
dave chilvers
Image Upload: Off
p.1 #11 · Help: 18mm or 21mm Carl Zeiss EF
I have a 21mm 2.8 contax and to be honest I`ve only seen the seriously bad distortion that every one talks about on a handful of occasions but then I`ve only shot about 10,000 images with it
Nov 02, 2009 at 02:52 AM
philber
Image Upload: On
p.1 #12 · Help: 18mm or 21mm Carl Zeiss EF
Here is one example where the mustache distortion is plainly visible. This shot is otherwise totally without value. That norwithstanding, I love this lens, which delivers superb IQ and is clearly the "star" in the Zeiss lineup of wide angles. I particular, I compared it to the new ZE version of the highly 28, which couldn't hold a candle to it. I expect the same would be true regarding the 18. In particular, the 21 is outstanding in flare control and absence of CA. Compared to a Canon, just ask member Snowboarder, who purchased a 24L II and a Zeiss 21 at the same time.
2 other shots show what the Zeiss can do in architecture, considering that I have owned it one week. The first one is already a slight crop. The second one is cropped approximately 200%.
Exif information
Model Canon EOS 5D Mark II
Date 2009:10:24 15:25:35
Original date 2009:10:24 15:25:35
Exposure time 1/60 sec
Focal length 21mm
Focal number f/8.0
ISO speed 100 ISO
Exposure compensation 0.0
Exif information
Date 2009:10:25 16:26:35
Original date 2009:10:25 16:26:35
Exposure time 1/200 sec
Focal length 21mm
Focal number f/7.1
ISO speed 100 ISO
Exif information
Focal length 21mm
Focal number f/7.1
ISO speed 100 ISO
Nov 02, 2009 at 06:05 AM
bobring
Buy and Sell: On
p.1 #13 · Help: 18mm or 21mm Carl Zeiss EF
Well, I made my decision & went for the 21mm. UPS delivered it about 3 and half hours ago. I went out to the beach to take a few shots. I don't think they'll show the Zeiss 3D effect as the sun was fading fast and I've found that my 1DsIII sensor really likes a lot of light to make my photos shine (but maybe that's just me!). Here are a few (very) quick samples to check out. The build quality is superb but now I have to start lifting weights to carry it!
No special processing (just exposure and levels):
Same photo with some oomph and PP:
Nov 04, 2009 at 09:35 PM
philber
Image Upload: On
p.1 #14 · Help: 18mm or 21mm Carl Zeiss EF
Nice test shots, Bob. You have every right to be pleased.
Nov 04, 2009 at 10:23 PM
Lost password?
