Roland W Offline Image Upload: On
If you are talking about the off center set screw that you can tighten from the bottom, it is to lock the tripod head on to the plate after you have screwed it on to the main center stud firmly.
The hook is to hang weight from your tripod to make is more stable. You can use what ever is available, but a camera bag or backpack can work out well, and you will likely have that with you all ready. You may need a short cord or some hook device to make it easy to attach and remove the weight.
Be sure to check that the your plate is firmly attached to your tripod. Use the provided wrench to verify the clamping screw is very firmly tight. There have been cases where it is not well tightened when delivered.
