Beverly Guhl Offline Dedicated FM Upload & Sell: Off
p.1 #4 · Modifier Test: can you guess? | |
cgardner wrote:
Your test protocol is flawed unless all you want to do is compare relative efficiency (i.e. exposure difference) between them. For a more objective test you should normalize the exposures. Otherwise its impossible to objectively compare the specular highlights and wrap in the shadows.
Instead of shooting all at the same aperture / power put a white textured target in the scene and adjust flash power with each modifier so the white target -- the baseline for exposure in the highlights -- is just below clipping. Then all the skin highlights will be identical and the tone of the shadow can be objectively compared.
Chuck
Yes, I was just testing efficiency. Very basic test for my needs. I didn't shoot at the same power, but I did modify each light output to achieve f/7 exposure (or is that what you meant?). I can't get rid of the specular highlight on a mannequin w/out everything else being under-exposed anyway. A better test would be on a person, which I'll be doing soon. I also know some modifiers give a different look depending on how close they are to the subject, and as I said in my disclaimer this was not that kind of test. I was just curious to see what results I could expect if I put any modifier next to my lens and took a picture. Thanks for the suggestions!!
