theSuede Online Image Upload: Off
p.1 #7 · Sigma 150, not opening to 2.8 | |
No it doesn't, the Canon system is just to stupid to correct for the purely optical phenomenon. Canon says F/2.8 when true F/no is really higher. This is not just 3d party lenses, same goes for Canon's own lenses. As an example, the EF 50F/1.4, a pure "unit focusing lens", should (correctly reported) be something like 60F/2.0 at MFD, if memory serves me right.
Aperture number (true aperture size relative to focal length) DOES increase if you focus closer, minimum F/no is only reached at infinity (or at least "long" distance focus). This is a physical property that Canon just choose to compensate for in another way (by using longer shuttertimes) - without telling you so.
If you'd care to check, grab a frame of a big white surface (evenly and constantly lit), at maximum aperture and 3-5m focus distance. Then do the same at MFD. Your shot taken at MFD will have a longer shuttertime, but will be exactly as bright.
