R. Francois Offline Image Upload: Off
p.1 #3 · Sigma 24-70mm F2.8 IF EX DG HSM | |
i owned the 24-70 EX DG (non HSM) and used it a lot, portraits, events weddings, landscapes, even some simple macro work. Al on a cropped body. Eventually i got other glass and i didn't use it that much anymore.
When i went full frame i started to use it again but for some reason i did not like it that much anymore. The AF was rather clunky and felt like hit or miss. So i decided to go for the upgraded version with HSM and the all new design. That lens was fast to focus, colors are great same for the contrast. When focused correctly it was very sharp, even wide open i had no complaints. But it had a terrible amount of front focusing. Even the max adjustment on my camera wasn't enough. I've returned it and got a original nikkor instead. Which is great...
Despite the fact that i don't have the lens you mention, i will still recommend it, just check for any issues while you can return it... (but that goes for any lens hmm?)
few samples (manual focused since the AF was of no use on my version)
