Rules: One new topic per day
FM Forums | City, Still Life & Abstract | Join Upload & Sell
Archive 2009 · Just learning PTGui
Kirk P.
p.1 #1 · Just learning PTGui
1st 3 out of PTGui Pano tool.
From MS Company meeting last month.
No reading how, just wanted to see what I could whip out righ off the Bat, so to speak.
jpegs only.
C&C Welcome.
Oct 27, 2009 at 11:49 PM
Kirk P.
p.1 #2 · Just learning PTGui
Is this in the wrong Forum?
Oct 29, 2009 at 02:09 AM
rklee
p.1 #3 · Just learning PTGui
Very nice! First one is my favorite.
Oct 30, 2009 at 05:20 AM
freespirit
p.1 #4 · Just learning PTGui
Images are great.
Tell us a little about what goes into each image.
How many jpegs, lens mm and how long to process each pano
Oct 30, 2009 at 02:24 PM
Kirk P.
p.1 #5 · Just learning PTGui
Thanks,
The 1st one is around 15 frames with a 24mm in vertical. as these are my 1st images using PTGui, I still have ALOT to learn. I think the 1st one is pinched to much, maybe used to many images as there was alot of overlap between images.
Maybe I will revisit it and try the blend using every other image.
2 and 3 are also with the 24mm in Vertical mode. 6-7 images.
I then tweaked them in CS3 using highlight and shadow adjustment to help with the darkness under the roof and the highlights of the sky, even hand painted some burning to help where I thought it was needed.
What I wanted to express was the amount of rigging tied into the roof to support all of the truss's for lighting and the truss's that were used to create the light boxes for the projection.
You can see where the outside of the large black boxes are on there own motors so the can travel up and down to allow light to get on the grass when not in use. plus they can run the sprinklers.
Oct 30, 2009 at 04:39 PM
freespirit
p.1 #6 · Just learning PTGui
The detail is amazing.
What was the overlap in degrees between 15 frames in image 1 and the 6-7 in image 2 & 3. Presumably you used a panoramic head to help with the overlaps.
And of the final image in 1,2 & 3 whats the field of view in degrees in each final image.
Is it more than 180 degrees.
Oct 30, 2009 at 06:38 PM
Kirk P.
p.1 #7 · Just learning PTGui
Thanks. If I had to guess the overlaps in 1 was around 8-9 degrees.
based on my guess of the angle divided by 15.
Images 2 and 3 are covering around the same angle, but only shot 9 images to cover that angle.
I'm really bad at the math and like I said, this was my 1st attempt using this pano program, not much more then load and go. never read anything in the help file yet.
Played with the composition in the preview, still trying to figure out what the main changes are when using the Horz. and vert. sliders other then what I see. then just slid them around to what I felt look best.
I know I am missing out on alot that is available to me with this program, but i am a very impatiant person, hell, it takes alot for me just to type it all up with 3 fingers
I'm limited on time as work is very slow right now, and with wife at work and all the home chores, rather experiment then read .
By the way, these are all handheld, shot with my D3 and my old 24mm 2.8.
Thanks again for the questions.
Oct 30, 2009 at 07:02 PM
freespirit
p.1 #8 · Just learning PTGui
Great result though.
And thanks for the answers.
Oct 30, 2009 at 07:21 PM
showpro
p.1 #9 · Just learning PTGui
Nice! I was sitting right around the third base line, just to the left of the batter's box.
Oct 31, 2009 at 04:32 AM
Kirk P.
p.1 #10 · Just learning PTGui
Cool, what was your gig?
Oct 31, 2009 at 05:17 AM
showpro
p.1 #11 · Just learning PTGui
I'm a Microsoft employee!
Oct 31, 2009 at 05:55 AM
Kirk P.
p.1 #12 · Just learning PTGui
Oh. right, I thought you might have been show crew
I mean with a name like Showpro
I was the onstage handheld camera Op. for the event.
My Images
Oct 31, 2009 at 04:05 PM
showpro
p.1 #13 · Just learning PTGui
Nice work.
Actually, I used to be in the biz. Showpro comes from a software package I wrote for myself and then marketed, called ShowPro MIDI. I don't do that anymore, but the vestige of the Web site can be seen here: http://home.comcast.net/~showpromidi/
Nov 02, 2009 at 05:31 PM
Leoric
p.1 #14 · Just learning PTGui
Speaking of ptgui, what do you think of these panos? Unfortunately, I cannot post them here, because they are 3D. Citroen C4 Coupe, Toyota iQ and Porsche Cayman S
Nov 03, 2009 at 08:11 AM
showpro
p.1 #15 · Just learning PTGui
From my camera phone:
Is that you, shooting Ballmer?
Nov 03, 2009 at 05:35 PM
freespirit
p.1 #16 · Just learning PTGui
@Kirk
So if I was going to do the same in PTGui,
what would your advice be?
Or if you went to the same venue, what would you do different?
Nov 06, 2009 at 02:54 PM
Donald Gray
p.1 #17 · Just learning PTGui
Great Panos beautifully executed.
I am just started with PTGUI too - I love it...
I am also just starting with high definition panos which add another dimention and is great fun to do.
The HD process =
Take the pano shots
Stitch 'em with PTGui
Take 'em apart with KRpano
View with Flash player
If you want to extend or augment the PTGui features have a look at krpano.com
This is the awsome gigapano that inspired me to get PTGui & Krpano
Nov 08, 2009 at 12:55 PM
Donald Gray
p.1 #18 · Just learning PTGui
I posted my suggestion of krpano before I saw yours - They are great!
I hope this does not hijack the thread - It is intended to encourage Kirk to go further, if he hasn't seen this technique...
Nov 08, 2009 at 01:03 PM
freespirit
p.1 #19 · Just learning PTGui
Donald. Absolutely Agreed on that.
That Gigapano is inspirational.
Did you check and confirm if PTGui was used on that one?
I have one or two venues that would definitely benefit from the treatment.
But the resources necessary - its another story
Nov 08, 2009 at 02:25 PM
Donald Gray
p.1 #20 · Just learning PTGui
The creator stated:
[QUOTE]
-1200 raw pics Canon 5D MK II FL 100mm -> 310 for full sphere
-exposure between 15 sec. and 1/2 sec
-focus stacking and 3 wb settings (3000k, 5500k, 9000k)
-NN5 -PTGui
-3 days pc running to calc the sphere -cube size 32768x32768
-8 hours photoshooting
-2 month to combine the different focusing layers ,editing the WB and exposure layers
[/QUOTE]
Sorry to be a guilty party but please do not let us hijack this thread...
Nov 08, 2009 at 03:15 PM
Kirk P.
p.1 #21 · Just learning PTGui
No, that's James with the steadycam. watch for him on Monday night football.
I was handheld up front by and on the stage.
When they did the new computers demo, I was on the right and James was on the left.
Nov 09, 2009 at 03:17 AM
Kirk P.
p.1 #22 · Just learning PTGui
freespirit wrote:
@Kirk
I don't really have any advice as I am just starting with this program.
If I was going to shoot it again, I would have shot everything form the pitchers mound and did Full coverage, But Like I said I have alot to learn as I didn't even know the software could do the 360 full immersion stuff.
Nov 09, 2009 at 03:19 AM
Kirk P.
p.1 #23 · Just learning PTGui
The HD process =
Take the pano shots
I have much to learn, and in need of faster computer.
Nov 09, 2009 at 03:20 AM
eNoBlog
p.1 #24 · Just learning PTGui
Nicely done. I have PTGui Pro and love it, especially for HDR panoramas.
Nov 10, 2009 at 10:57 AM
