FM Actions & Plugins support
Workflow Guidelines
Archive 2009 · Anyone use a dry mounting press?
Jacob D
p.1 #1 · Anyone use a dry mounting press?
I was given a "Seal Commercial 210m" dry mounting press recently. I don't know much about dry mounting; I'm just starting to do some research on the web. If anyone has experience to share it would be appreciated, especially regarding mounting board and tissue selection.
Oct 27, 2009 at 05:39 PM
tomrock
p.1 #2 · Anyone use a dry mounting press?
I have one. I use ColorMount tissue to mount prints from an Epson 3800 (and now 3880). Works great.
Oct 27, 2009 at 08:36 PM
Jacob D
p.1 #3 · Anyone use a dry mounting press?
Thanks, I came across that tissue, I think on B&H. Do you use a fairly low temperature when mounting prints from your Epson printers?
Oct 28, 2009 at 12:12 AM
papageno
p.1 #4 · Anyone use a dry mounting press?
SEAL USED TO MAKE TEST STRIPS FOR TEMPERATURE. iF THEY STILL EXIST, THEY ARE A GOOD INVESTMENT AS THE THERMOSTATS IN THESE MACHINES GET DUBIOUS OVER THE YEARS.
WHEN STARTING, BE SURE YOU ALLOW THE MACHINE TO COMPLETELY WARM UP. PREVENTS UNEVEN MOUNTING DUE TO TO INCOMPLETE WARMING.
THEY ARE PROFESSIONAL MACHINES DESIGNED FOR HEAVY USE. ENJOY!
Oct 28, 2009 at 01:55 AM
tomrock
p.1 #5 · Anyone use a dry mounting press?
ColorMount tissue is designed for pretty low temp. I think it's like 190F?
It's great having my prints stay flat.
Oct 28, 2009 at 11:06 AM
chesapeake
p.1 #6 · Anyone use a dry mounting press?
I have used the commercial Seal Mount Systems for years. The low temperature mounting tissue is what you need for todays papers. Try 165 degrees on a test paper and mounting board. You can increase your time a bit if the temperature is too low. If after approx 1 minute you still are not getting good adhesion, increase your time at 15 sec intervals until the tissue binds to the board. By the way, the Color Tissue Mount is removable. A second important tip, place your mounting board in the press and close the press for 1 1/2 minutes before placing the print and tissue on it. You do this to drive out the residual moisture which will cause the board to curl otherwise. Also, try and get a sheet of silicone treated "mounting release" paper to place between the print surface and the platten of the mounting press. This will prevent the mounting tissue from sticking to the platten and the texture of the paper surface unaltered. If you can get a tacking iron to tack down the tissue before mounting this will also help. You can use foam board or regular standard single or double weight mount board.
Good Luck-Chuck
Oct 28, 2009 at 11:48 AM
mcbroomf
p.1 #7 · Anyone use a dry mounting press?
Chuck gave some great advice. The only other thing I'd mention is to keep things super clean. It's horribly easy to get a bit of grit between the press and the print and make a small dent that can't be recovered.
BTW I use dry mount tissue that comes on a roll and recently had to throw out 2 prints because I hadn't noticed that a section of the roll had a flaw (a diagonal wrinkle) that left a pronounced line across the print.
Mike
Oct 28, 2009 at 01:23 PM
Robert Snow
p.1 #8 · Anyone use a dry mounting press?
I agree that you really need a tacking iron.
Watch E-bay and you can pick one up at a reasonable price (less than $50).
bob snow
Oct 28, 2009 at 03:05 PM
chesapeake
p.1 #9 · Anyone use a dry mounting press?
One other thing I left out, if you can't put your hands on seal release paper, you can use a sheet of plain brown wrapping paper. Occasionaly I have used this technique and it works pretty well, even for glossy surfaces. As a side note, I had MPIX mount some stuff for me and they didn't use pre dried board, the results were curled prints (Grrrrrrrrrr)
Oct 29, 2009 at 08:53 AM
