FM Actions & Plugins support
Workflow Guidelines
Archive 2009 · Colormunki worth the money?
Jim Quinn
p.1 #1 · Colormunki worth the money?
Hi,
Like so many others, I have color management issues.
Although I hope to upgrade my computer soon, probably to a new 27" iMac when they become available, I now do my photo editing (usually in a dim basement office) on a 15" Mac G4 PowerBook. I have been calibrating the laptop screen regularly with an original PanTone Huey unit. Although laptop screens don't have terrific reputations for color accuracy, and the Huey is obviously an inexpensive device, I have had large prints made by professional labs from files generated by my computer - without any need for color adjustments. I must be doing something right, at least now and then.
Until recently, I have been making prints on an Epson 1280 printer, but that experience hasn't been a lot of fun. The print colors never matched the screen display, usually running too red and too dark. As a work-around (and I've learned to hate work-arounds), I have been letting the printer, rather than Photoshop, control the printing. By adding a fixed set of printer color adjustments (to lightness and contrast, among others), I have been able to make prints that resemble my screen displays. But I would prefer my printer to make prints as I saw them in Photoshop.
Curiously enough, I have made some letter-sized prints on a really cheap Canon printer, a $60 IP1800 from Office Depot, letting Photoshop control the printing process. These prints look almost exactly like the monitor! Maybe I just have an Epson allergy.
Within the last few days, I have installed a new Epson 4880 printer. Although I'm still learning to use this complex machine, my first few small test prints, once again, don't match the screen display. They're too dark and probably too yellow; areas that appear as real red on the screen (and in printer-controlled prints from my 1280) look brownish-red on the prints.
So I've decided to find a calibration device that will adjust the monitor and the printer output. I have read a lot of reviews here and elsewhere online about various calibration devices, and I've been attracted to the X-Rite ColorMunki for its versatility and, frankly, its price; with a current rebate, it's under $300 on Amazon. I'm sure that photographers with larger budgets than mine would consider this device less than ideal, but many online reviewers have had good results with it.
Of course there are other solutions on the market, and I'd rather make the right choice now than buy an "almost" product, be frustrated again, and have to start over a few weeks down the road.
I would appreciate your thoughts on what works for you. Thanks!
Jim Quinn
Oct 23, 2009 at 03:31 PM
george malamis
p.1 #2 · Colormunki worth the money?
With a properly calibrated monitor and the proper ICC paper profiles, any monitor calibration system will do the job. The colormunki adds the ability to calibrate projectors and make custom paper profiles. If you do not need the last two items, the cheaper monitor systems ($100 - $150)will do the job. Typically though darker prints are a symptom of a bright monitor so keep that in mind.
Oct 23, 2009 at 04:00 PM
Brit-007
p.1 #3 · Colormunki worth the money?
I was in the same boat and purchased the ColorMunki. I have just used it for the screen and prints are so much better. I have not tried the print profile yet as I do not do much in the way of printing. It did make a difference. I am using a Mac Pro and Dell 2408 screen.
Oct 23, 2009 at 07:11 PM
ModifiedPhoto
p.1 #4 · Colormunki worth the money?
For screen calibration, I prefer the Spyder3. For printer calibration (and if you use a projection screen perhaps), the ColorMunki does work as designed. It's a little tricky to get the printer calibration figured out at first but once it's done for a paper and ink type, it's not something you'll have to mess with again for some time.
Some time ago I posted some thoughts on the two here: http://modifiedphoto.wordpress.com/2009/05/14/screen-calibrated-tests-results/
Oct 23, 2009 at 08:54 PM
nathanlake
p.1 #5 · Colormunki worth the money?
I attended a photo expo here in Seattle recently and asked the Spyder sales rep if I should update from Spyder2 to Spyder3. I was shocked when, after asking what monitor I was using, he said the Spyder2 was just as good as the Spyder3.
He suggested the Spyder3 upgrade only for a very glossy monitor (I use the Apple Cinema, matte).
Oct 24, 2009 at 03:17 AM
Alan321
p.1 #6 · Colormunki worth the money?
Jim, I can't recall how to set up the Epson printer driver but check that your monitor calibration is not set too bright, as that will make prints look relatively dark. You want around 90-100 Cd/m2 but that is impossible to achieve on iMacs except by throwing away half of the tonal range offered by the graphics card - those monitors are just ridiculously bright.
I have only just got a Color Munki but haven't installed it yet. As it turns out the Software that came with my new NEC Spectraview monitor is incompatible with the ColorMunki and so I cannot fully utilize the internal 16-bit look-up table for profiling. Keep that in mind when considering buying the ColorMunki for whatever monitor you are likely to get.
In general I think any colorimeter is better than none, as they all do a reasonable job of profiling monitors (newer ones are needed for LCDs vs CRTs) for most colours, but the better ones do a better job of managing the more subtle corrections for grey tones and dark or bright areas. None can overcome a lack of colour gamut in the screen.
- Alan
Oct 24, 2009 at 09:09 AM
mdelrossi
p.1 #7 · Colormunki worth the money?
Alan,
I was just at the photo show and stopped by the NEC booth.
I asked the if the Munki would work with their monitors.
They said that you have to disable the munki software then it would work.
It's in the settings control on a Mac don't know where it would be on a PC.
I used to have a Spyder, I found it awfuly slow.
I rented an iOne with the printer calibration hardware, and it worked great.
Better monitor display and more importantly better prints.
So I bought the munki, it works great.
Prints match the monitor, it's fast, and it even reminds you to calibrate every so often.
My specs:
Mac pro 8 core
23" cinema display( soon to be retired, that's why I talked to the NEC people)
Epson 3800
a variety of papers
I hope this helps
mdr
Oct 24, 2009 at 01:19 PM
bluebird
p.1 #8 · Colormunki worth the money?
The Spyder 2 will also not work on the new generation of wide gamut monitors. 1 month after buying one, I swapped to a Dell 2408 and found the unit useless. they were less than sympathetic. Never buy them again.
Switched to a Color Munki - great product , fast and good profiles with the latest s/w. Printer ones are especially fast to do and as good as anything the spyder did for me previously.
Oct 24, 2009 at 03:14 PM
XFBO
p.1 #9 · Colormunki worth the money?
Ive never owned a calibrator, I think I understand the differences between monitor/printer calibration but can you just clarify something for me?
Regarding your remark above, "better prints" and "prints match the monitor"......is that due to your calibrating the printer?
Other than brightness/darkness issues, I cant see how calibrating a monitor [alone] will improve printed images, say, like misrepresented colors within a print?
Oct 25, 2009 at 03:27 PM
howardm4
p.1 #10 · Colormunki worth the money?
you always want/need to use a printer profile when printing. most/many paper mfgr's supply standard profiles for their papers. So having a custom print/paper profile will *improve* how close your calibrated monitor and real print match each other. Most people are content w/ std. paper mfgr profiles but a custom one gets you that much closer.
Oct 25, 2009 at 03:41 PM
Kaj E
p.1 #11 · Colormunki worth the money?
If you do not have a profiled monitor you do not know what the image actually looks like. This is true for tones and colors.
With a calibrated monitor you see the real image and by using the correct printer profile (printer and paper) you will get the true colors and tones in print..
Oct 25, 2009 at 05:26 PM
XFBO
p.1 #12 · Colormunki worth the money?
Ok thanks for clarifying.
Is it safe to say that if one plans on using 3rd party inks and a less popular paper that finding profiles will be difficult, making the purchase of a printer calibrator more logical?
Work with me here I need to justify the purchase to my other half.
Seriously tho, do I have that right, it would make me feel better if my understanding of color management is getting better.
Oct 25, 2009 at 05:58 PM
Kaj E
p.1 #13 · Colormunki worth the money?
Correct. Go for it !
Oct 25, 2009 at 06:16 PM
MidMadn
p.1 #14 · Colormunki worth the money?
Love my Munki.
Oct 25, 2009 at 10:46 PM
howardm4
p.1 #15 · Colormunki worth the money?
Thats exactly right. You're not likely to find profiles for 3rd party ink or oddball papers. You could have someone make them for you and the price varies from $20 - $100 per profile so if you like experimenting, it'd probably be worth it but otherwise, not so much.
Oct 26, 2009 at 01:50 AM
Karl7Feet
p.1 #16 · Colormunki worth the money?
I am using www.cathysprofiles.com with my Epson 3800 and could not be happier, and for $35 it is a great value.
Oct 26, 2009 at 02:52 PM
HerbChong
p.1 #17 · Colormunki worth the money?
what version of Photoshop?
Herb...
Oct 26, 2009 at 04:56 PM
mikaelo
p.1 #18 · Colormunki worth the money?
I'm very happy with the outcome from using a ColorMunki for calibration.
I use third party inks in a CIS, requiring me to profile unless I wan't to use one of the few papers the ink vendor supplies profiles for.
I use the printer for proof sheets and I have a good match to the wet process prints from my local lab I use as final product.
I also profiled my color laser, allowing me to do quick rough "how it looks on paper" proofs, thought it's gamut is quite different and more limited to the inkjet and wet process prints.
It's also very fast and easy to use, both for screen calibration and printer profiling.
Oct 26, 2009 at 05:12 PM
ModifiedPhoto
p.1 #19 · Colormunki worth the money?
Performance may be similar but the Spyder3 is said to be better for wide gamut displays and it has a larger sensor aperture which is said to make it better for very deep colors. They used to have a comparison on the website but it doesn't seem to show Spyder2 products at all anymore.
Oct 27, 2009 at 06:13 PM
MartinAS
p.1 #20 · Colormunki worth the money?
Hi
I have had the ColoMunki since just after it was available and I very pleased. I am sure there are more in deph units, but it does the job for me.
BTW ColorMunki makes me think that US spelling is the sxxxx. Color should be colour and munki monkey...
Martin
ps for progress also go metric
Oct 27, 2009 at 09:47 PM
XFBO
p.1 #21 · Colormunki worth the money?
Well, I pulled the trigger and ordered the Xrite Colormunki......hope it's not too difficult to use!
Oct 28, 2009 at 02:21 AM
Mirek Elsner
p.1 #22 · Colormunki worth the money?
If you believe your monitor is calibrated correctly, I'd recommend getting professionally created profile, for example from aforementioned Cathy. Not only it will give you a profile, that you know is correct, but also gives you instructions on how to set your color management properly. If you later decide to buy the ColorMunki, you will use it with greater confidence and knowledge how professional profiles look like.
Oct 28, 2009 at 03:43 AM
Alan321
p.1 #23 · Colormunki worth the money?
Buying profiles is ok if you don't change inks or papers but if you want the flexibility of using several papers and canvas then the cost of the profiles goes up. Some are (or were) a lot dearer than others.
I'm happy with the colormunki so far. Speed, ease of use, and results are all quite ok.
- Alan
Nov 01, 2009 at 07:58 AM
