lylejk Offline Upload & Sell: Off
p.1 #13 · Just installed Win7 64-bit. | |
Sorry; been busy getting things like I like it. For a quick report, here goes. Win7 found all (and I mean all) my motherboard device drivers which was fantastic. It did not find a driver for my favorite but old NIC (3COM 3C905TX; admit that it's over 8 years old). I replaced that with another NIC (like to keep my Network lazer printer separate from my Internet connection). Also, it was a waste (albeit, $99 not a bad price for the Pro Upgrade) since the only reason I got Pro was for XP-Mode which stinks. I'm using VirtualBox for my XP needs (have a few including Sandboxie which does not run in 64-bit mode; that's what VMs are for). 3 times better then XP-Mode, so if you haven't purchased Win7 yet, then, if you already have a legit license for XP, then forget Win7 Pro and go with Home Premium and download VirtualBox (Open Source, i.e., free). I now have my Ubuntu VM, Win98 VM (because I like UNO and Bicycle Solitaire which had a few issues with XP (though ran) and didn't want to take a chance with Win7), and of course XP Pro. VMs the way to go. Only challenge was setting my my shares between my VM and Win7 (so I can share files as needed; I will admit that XP-Mode did a fantastic job at setting up shares and VirtualBox required a little research to do this, but it's not really rocket science to me). I will upgrade my memory though since I only have 2G RAM (very spiffy with 2G by the way, but why not load as much as I can since I now finally have an OS that can use more RAM then 3.5G). I will add that now that it's been a week, I definitely have no regrets. Only challenge was getting my Lazer printer to work in the VM for XP (works great now in both VM and native Win7 modes). Only caveate that I've found was 2 speciallized software programs that I use for my Dad for downloading information from his Blood Pressure monitor that doesn't work at all in Win7, and, though it did recognize the device in my XP VM, the software still won't communicate with it unfortunately. I can use my XP Laptop so I'm not going to fret this little issue. Also, CS2 upgrade installed flawlessly (I released the license to re-install it in Win7) and of course both GIMP 2.6x and GIMP 1.2x installed fine (I'm a GIMPer, but I do have need to use CS2 for my Leica and some cool Actions and filters that I won't live without).
So, all, and all, go 64-bit all the way. It's the future and you won't have any regrets. Also, if you can afford it, load up your RAM as much as you can because now you can. Even with 2G RAM, my system seems more spiffier then XP; even boots within a minute which is cool. I'm only using Windows Security Essentials since I'm doing any online things using a VM in a sandbox (Sandboxie), so I'm not worried at all with mal-ware (using Threatfire Trojan only protection in the VM; if my Sandbox gets infected, then I will simply delete it. If my VM get's infected, then I will just do a Snapshot recovery).
Yes I did a clean install on my C: partition (kept D: and E: intact). It took all of 20 minutes to complete the OS install (fastest install since Win95; wish Vista would have been this fast; yes, I fix PCs for a living). I've heard that a true upgrade (i.e., if you have Vista) can take over 3.5 hours to do; hope to never have to experience this. lol
