Archive 2009 · Nikon Super Coolscan 5000 Problems
donweixl
p.1 #1 · Nikon Super Coolscan 5000 Problems
Hi: Is there a board or forum where I can inquire about problems I am having with my Nikon Super Coolscan 5000 scanner?
Thanks,
Don Weixl
Oct 19, 2009 at 10:25 PM
Bernie
p.1 #2 · Nikon Super Coolscan 5000 Problems
A number of us here at FM have or had scanners. You can bounce questions and see if they get answered...
Oct 19, 2009 at 11:23 PM
sjms
p.1 #3 · Nikon Super Coolscan 5000 Problems
pray tell what is the issue
Oct 19, 2009 at 11:24 PM
donweixl
p.1 #4 · Nikon Super Coolscan 5000 Problems
With black and white negatives I get super high contrast scans...no middle tones at all.
Oct 20, 2009 at 01:57 AM
sjms
p.1 #5 · Nikon Super Coolscan 5000 Problems
1- are you scanning them on the correct side?
2- are your negatives thin
Oct 20, 2009 at 02:30 AM
Bernie
p.1 #6 · Nikon Super Coolscan 5000 Problems
Try the FAQs?
http://support.nikontech.com/app/answers/detail/a_id/254/p/25%2C104/page/2/r_id/116678
Oct 20, 2009 at 02:50 AM
donweixl
p.1 #7 · Nikon Super Coolscan 5000 Problems
Thanks guys. The neg was in the right side up and wasn't too thin.
I will try it with the "ice" turned off as recommended in the FAQ link.
I may have had a bad connection with the neg adapter. I pulled it out and replaced it with the slide adapter, successfully scanned a slide and then went back to the neg adapter and did a successful neg scan...
Thanks for your input.
Oct 20, 2009 at 05:29 AM
sjms
p.1 #8 · Nikon Super Coolscan 5000 Problems
excellent! good scanning ahead.
Oct 20, 2009 at 02:30 PM
Greg Campbell
p.1 #9 · Nikon Super Coolscan 5000 Problems
Yea, I think you NEED to disable the ICE thingy. Hardware dust detection used an infrared light source to illuminate the dirt. Unfortunately, silver based film is opaque to IR, so the ICE goes haywire, thinking that all dense areas are gigantic blobs of dirt.
As a general rule, you can't use ICE (or Canon's similar FARE) with B&W or Kodachrome film. C41 and E6 chemistries are fine.
Oct 22, 2009 at 04:00 AM
harrygilbert
p.1 #10 · Nikon Super Coolscan 5000 Problems
I had the same problem with mine - be sure to disable ICE. Then I found Vuescan software, which I now use instead of the kludgy Nikon software, which typically has problems interpreting the frame separators on many color positive films..
Nov 13, 2009 at 02:45 AM
calemon
p.1 #11 · Nikon Super Coolscan 5000 Problems
How is Vuescan at some of the "restoration" functions that NikonScan offers with the use of hardware such as ICE4? What about the all-software functions like GEM and aged-film colour correction? Does Vuescan directly use ICE (ie. the infrared pre-scan) or just an algorithm to remove "suspected" dust?
I already have to use the Vuescan-driver kludge to get NikonScan to run under Vista x64 and I forsee even more problems with Win7 since it appears that Nikon is abandoning the Coolscans. I only scan old film so I need things like ICE and aging correction.
Nov 13, 2009 at 01:26 PM
harrygilbert
p.1 #12 · Nikon Super Coolscan 5000 Problems
Download a trial version and test it. The "pro" version (which I bought) has all the features the Nikon software offers (including the infrared dust removal - "ICE") and also offers multiple simultaneous output.
Nov 13, 2009 at 10:20 PM
jamie123
p.1 #13 · Nikon Super Coolscan 5000 Problems
Try: www.hybridphoto.com
Nov 14, 2009 at 10:42 AM
willax1
p.1 #14 · Nikon Super Coolscan 5000 Problems
Hi Vuescan uses the infrared channel for cleaning.You can also scan to a raw file and do adjustements later on without having to rescan your valuable film.It can also
process digital raw files from most cameras as far as I remember
Nov 18, 2009 at 03:29 AM
harrygilbert
p.1 #15 · Nikon Super Coolscan 5000 Problems
I'm also finding that Vuescan offers a lot of color balance flexibility if you wish to do that while scanning. I'm going through 6,000 30-year old slides (combination of Kodachrome, Ektachrome, and Agfachrome), and it's a joy to just dial in the film brand and select the color balance based on the shot's ambient lighting. Makes post-processing a lot easier. I just batch process through Neat Image, and then into Photoshop.
And right in the middle of that task, my wife wanted a multi-page document scanned on my flat-bed and converted to PDF and OCR - which Vuescan did easily and accurately. Probably the best $79 investment I've made in a long time.
Nov 21, 2009 at 04:17 AM
