Archive 2009 · Wireless CLS question
cm0rris0n
p.1 #1 · Wireless CLS question
I never know which forum is more appropriate for a question like this, so in case it's this one, could you please check out the following:
http://www.fredmiranda.com/forum/topic/824372
Thanks,
Chris
Oct 15, 2009 at 06:53 PM
cm0rris0n
p.1 #2 · Wireless CLS question
bumping this as I've added new info to the thread and my problem still isn't solved.
Oct 28, 2009 at 12:54 AM
cgardner
p.1 #3 · Wireless CLS question
Not familar with the detailed workings of the CLS system but from the description it sounds like it might be hot shoe contact related. That's a problem that plauges the Canon 580exII.
Check /clean hot shoe contacts, that the hot shoe on camera isn't loose and that all the pins on the flash are moving freely.
Chuck
Oct 28, 2009 at 10:30 AM
f1.2
p.1 #4 · Wireless CLS question
Are you sure the camera is not in commander mode. Two commanders i.e. sb800 and camera might be in conflict.
I vaguely remember a similar issue when I had a D70 years ago.
Erik
Oct 28, 2009 at 10:59 AM
cm0rris0n
p.1 #5 · Wireless CLS question
Chuck, I tried to clean the hot shoe contacts and all the pins seemed to be ok.
Erik, I've set the D700 on each of the different modes it has and I seem to get the same result, so I don't think there's a conflict there once the sb-800 is on the hot show.
During more testing, I ran into something else that's weird. I noticed that every once in awhile the 600 would fire correctly under this scenario, so I tested 20 pops and 65% of the time I got the error beeps, 20% of the time it fired like it's supposed to, and 15% of the time it did neither (just sat there).
Oct 29, 2009 at 06:46 AM
Fred Amico
p.1 #6 · Wireless CLS question
One more thought for you. I just got through reading a thread here ( I think in the Nikon forum) about D700's with hot shoe issues, causing intermittent flash problems. See if you can find that thread and perhaps notice any similarity with your problem. If so, your 700 might require a trip to Nikon repair. Good luck, and hope it turns out to be something simpler than that.
Oct 30, 2009 at 04:55 AM
