kenyee Offline Image Upload: Off
p.1 #12 · Radiopopper JrX can't trigger Speedotron packs | |
Just a followup on this...the JrX Studio definitely has a hardware bug so it won't sync some packs/heads.
Someone on the flickr forum can't get his Travelite strobe to fire.
I also got a mono-mono 1/8" to 1/4" adapter for the Speedo 805 pack to make sure I wasn't shorting any JrX signals (the JrX comes w/ a stereo adapter but I was worried Speedo put their ground connection too low) and it doesn't fire.
Measured sync voltage at -63V (yep, reverse polarity), so I made up a reverse polarity sync cable, checked voltage to verify it was +63V and it still doesn't fire.
If you're using this w/ anything besides AB/WL strobes, make sure you check when you get it...
