What are the criteria?
Archive 2009 · Piano
KyleR.
p.1 #1 · Piano
Thanks,
Kyle
Oct 09, 2009 at 08:28 PM
Bob Jarman
p.1 #2 · Piano
Kyle,
Would you mind if I played a bit?
Bob
Oct 09, 2009 at 08:50 PM
KyleR.
p.1 #3 · Piano
Bob Jarman wrote:
Kyle,
Bob
Not at all
Oct 09, 2009 at 08:51 PM
AuntiPode
p.1 #4 · Piano
Interesting images. They break many "rules" but seem to work anyway. I'm of two minds about the color balance of the second. For your consideration:
Oct 10, 2009 at 12:34 AM
KyleR.
p.1 #5 · Piano
thanks I really like that.
I was wondering how I could make the keys white.
did you just use the clone stamp?
Oct 10, 2009 at 02:31 AM
AuntiPode
p.1 #6 · Piano
I changed the color balance of the keys in multiple stages. I didn't use the clone stamp. I liked the red/gold Steinway logo, so I treated the keyboard separately from the logo. I created a duplicate layer and used the middle gray eyedropper tool in the curves (Image>Adjustments>Curves) and picked a place on the lower edge that might be almost gray. I tried various places until I found one that looked as good as I could make it. Then I used the eraser to erase the upper part of the layer leaving only the keyboard with the curves adjustment. I flattened the layers and made another duplicate layer. Using Images>Adjustments>Color Balance I varied the sliders for shadows and middle and highlights until the keys look as they do. Then I again erased the area above the keyboard to retain the red/gold logo.
Oct 10, 2009 at 04:07 AM
KyleR.
p.1 #7 · Piano
Wow.
Thanks AuntiPode.
Thats a little advanced for me as i am new to photoshop haha.
I'm glad you like the pictures.
I would like to know, which rules do they break?
Oct 10, 2009 at 01:44 PM
Bob Jarman
p.1 #8 · Piano
KyleR. wrote:
Bob Jarman wrote:
Kyle,
Bob
Not at all
Sorry Kyle,
Haven't gotten there - was looking at the BW - changing to W7x64 at the moment.
Bob
Oct 10, 2009 at 04:08 PM
KyleR.
p.1 #9 · Piano
Bob Jarman wrote:
KyleR. wrote:
Bob Jarman wrote:
Kyle,
Bob
Not at all
Sorry Kyle,
Bob
NO problem Bob,
I was thinking about changing it to black and white, i decided not to because i liked the goldish color. Im excited to see how your version comes out though!
I just tried making the keys black and white and keeping the gold letters, similar to what auntipode did.
Tell me what you Think!
Oct 10, 2009 at 04:21 PM
AuntiPode
p.1 #10 · Piano
I like it. Two small tweak suggestions to try:
1. Make a duplicate layer and apply the Unsharp Mask filter , selecting values that make the forward key edges appear more sharply focused. (When the look sharpened the rest of the shadowed keys will be over-sharpened.) Remove or erase the duplicate layer from the edge of the key shadow and above.
2. Because the highlights below the keys give away the game, try using the clone stamp to remove them. As a tip, if you haven't used the clone stamp this way, alt or option click on a black part of the edge. Move the cursor onto the beginning of the gray edge of a highlight. Then click with the mouse but don't release the click and slide the mouse along. This lets to change a streak at a time. If you make a mistake, the undo command reverses the entire streak.
Oct 10, 2009 at 09:08 PM
AuntiPode
p.1 #11 · Piano
1. In the first the keyboard is centered and the converging lines of the keyboard lead to the center of the image. To the composition general guidelines, that is considered a static and less interesting composition. The rule of thirds suggest an image is more appealing if the center of interest is roughly one third of the distance from two edges of the image. However, many forget that the rule of thirds is only a guideline and not a rule written into the fabric of the universe like a law of gravity.
2. The DOF is deep enough that the furnishings of the room are sufficiently sharp to distract interest from the center of interest. However, for this image to me the furnishings add context that to me add to the image, making is an exception. Note that others who appraise the image may disagree.
Sometime an image works best when it breaks a rule or two. Nevertheless, it helps to understand the guidelines of composition and to understand you are using an unconventional composition because it works better for a given image.
Oct 10, 2009 at 09:22 PM
KyleR.
p.1 #12 · Piano
Thanks auntipode.
Seems a little omplicated but i'll try it.
Oct 10, 2009 at 09:40 PM
AuntiPode
p.1 #13 · Piano
KyleR. wrote:
Thanks auntipode.
Not essential, but it doesn't hurt to add PP tricks to your bag, does it?
Oct 10, 2009 at 10:09 PM
Bob Jarman
p.1 #14 · Piano
Kyle,
RW on each...first to correct distortion, warm it up, vignette/blur and maybe give it an archival flavor.
The second - conversion to BW in CS3 using BW Styler plugin, adding a touch of grain...silver gelatin tone
Just two more interpretations,
Bob
Oct 11, 2009 at 01:23 AM
KyleR.
p.1 #15 · Piano
Bob Jarman wrote:
Kyle,
Bob
Thanks Bob:
I think yours is definitely an improvement on the first pic.
I cant decide on the seond one if i like yours better or mine
Oct 11, 2009 at 02:34 PM
Bob Jarman
p.1 #16 · Piano
Kyle,
I prefer the color version but the keys are a bit hot for me - all that really matters is which you prefer
Bob
Oct 11, 2009 at 04:00 PM
sbeme
p.1 #17 · Piano
I like the BW's best. Especially the direct look at the keys and Steinway & Sons.
I also like the haziness of the on angle shot, but find the room and furniture pulling my eye too far away, even though they define a setting.
Scott
Oct 14, 2009 at 01:31 AM
KyleR.
p.1 #18 · Piano
Thanks Sbeme!
Oct 14, 2009 at 10:19 AM
