Macro World Resource
FM Forums | Macro & Still Life | Join Upload & Sell
Archive 2009 · Reversed 18-55
GC5
p.1 #1 · Reversed 18-55
Tried out a reversing ring with my 18-55 tonight. I found it way harder to use than the 100 macro, which I am far from mastering as it is. Because the working distance was so small, I handheld only. I also found that it was difficult to focus with the very dark viewfinder (I wasn't shooting in great light). For some reason, my liveview would not work either. My flash was also harder to get right, I think because ETTL data wasn't being transmitted properly. I finally just set it to manual and -1.5 exposure compensation. As you can see below, DOF is crazy thin. Still, this promises to be lots of fun even if it's more work than macro shooting with a dedicated lens. I will definitely keep the reversing ring in my bag for when i want a quick and light macro.
Anyway, here's an idea (no bugs handy) of how it performed. All shots from 18-40mm:
1. The "E" from my Dell laptop - about 1 cm across. Scary fringing. http://farm3.static.flickr.com/2647/3994473790_55f3dc9827_b.jpg
2. Circuit board: http://farm3.static.flickr.com/2592/3993713657_e2ab26156d_b.jpg
3. Teeth from pliers. You can see the grain in the steel and a fleck of paint barely visible normally. The slight angle shows how narrow the focus plane is: http://farm3.static.flickr.com/2611/3993714287_0cdc2d1687_b.jpg
4. Goose down at 18 mm. About an inch of working distance. DOF is crazy thin, this feather is about 1.5 cm long. http://farm4.static.flickr.com/3442/3994476160_be4fe7e6c4_b.jpg
5. Context for the down:
http://farm4.static.flickr.com/3441/3993715431_2613e8f06c_b.jpg
Don't know if anyone will find this helpful or not, but as they say, "the fun's in the doing."
Edited on Oct 09, 2009 at 10:12 AM · View previous versions
Oct 08, 2009 at 08:08 PM
LordV
p.1 #2 · Reversed 18-55
Good series- shows what can be done with a kit lens ! - makes an interesting little zoom macro lens
Brian v.
Oct 09, 2009 at 12:46 AM
Dalantech
p.1 #3 · Reversed 18-55
Well done!
Check out Evan's work over at Deviant Art: http://billyunderscorebwa.deviantart.com/gallery/#Macro-Bugs -he's shooting macro with a reversed kit lens.
Oct 09, 2009 at 12:56 AM
kionne_szichri
p.1 #4 · Reversed 18-55
shameless plug...
check mine too... all done using reversed kit lens or a combination of cheap ET + reversed kit lens... dheadconcepts
Oct 09, 2009 at 08:08 AM
GC5
p.1 #5 · Reversed 18-55
Thanks. It was fun trying to figure out how this performed - the shots show some pretty obvious technical problems. I'd like to try stopping it down and detaching from the camera with the DOF preview depressed, but I haven't found anything making clear whether this will work with an EFS mount (it reportedly does with EF lenses).
Nice work by Evan and Kionne.
Oct 09, 2009 at 08:51 AM
Adrian Jones
p.1 #6 · Reversed 18-55
Good series, nice work with a kit lens.
Adrian
Oct 09, 2009 at 05:57 PM
ersatz
p.1 #7 · Reversed 18-55
Does the IS on the 18-55 help at all or is it better to turn it off? I haven't bothered to use EF or EF-S lenses because pressing the DOF and then trying to release and detach the lens is a bit of a hassle. But if IS is viable and given the 18mm focal length I may have to try it in lieu of using the reverse mount Canon FD 28mm lens.
Oct 13, 2009 at 10:44 AM
reno.peterson
p.1 #8 · Reversed 18-55
Your IS will not work in this application. It requires the electronic contacts and full focus ability.
Oct 13, 2009 at 11:05 AM
GC5
p.1 #9 · Reversed 18-55
Correct. IS will not work and I just left it off.
Oct 13, 2009 at 11:37 AM
