Archive 2009 · Samyang (Vivitar, Bowen, et al) 7mm/8mm f3.5 Fisheye
sworth
p.1 #1 · Samyang (Vivitar, Bowen, et al) 7mm/8mm f3.5 Fisheye
I just ordered one of these. Has anyone here run one through its paces yet? It looks very interesting. I want to try to figure out how to do quicktime vr panoramas, and this lens seems to be the trick.
Oct 06, 2009 at 07:41 PM
cogitech
p.1 #2 · Samyang (Vivitar, Bowen, et al) 7mm/8mm f3.5 Fisheye
For a crop camera, the Peleng might be just as good and cheaper. For FF, the Zenitar.
I'm pretty sure the Samyang/Bower/Polar/(ad infinitum) is for crop only, so be aware of that.
Oct 06, 2009 at 07:49 PM
sworth
p.1 #3 · Samyang (Vivitar, Bowen, et al) 7mm/8mm f3.5 Fisheye
Apparently it uses a different type of projection which makes for much better distortion at the edges of the frame. It's possible to shave the lens hood off using a dremel tool and make it work with FF. In fact, you can shoot a complete 360 degree panorama in just four shots!
See...
http://michel.thoby.free.fr/SAMYANG/Early%20test%20report.html
http://www.lenstip.com/index.php?test=obiektywu&test_ob=160
http://flashpanoramas.com/forum/showthread.php?t=2489
Oct 06, 2009 at 09:02 PM
dasrocket
p.1 #4 · Samyang (Vivitar, Bowen, et al) 7mm/8mm f3.5 Fisheye
I used it on a 1Ds and a 5D. You can unscrew the rear element filter and it will work on FF. It is one of the most underrated lenses and a very well kept secret by those who own one. I sold mine when I left DSLR-land but did love it when I had it.
George.
Oct 06, 2009 at 10:11 PM
