colinm Offline Image Upload: Off
p.1 #2 · Monitor Calibration Hardware | |
The Spyder3 Elite is actually quite good. The software and support occasionally leaves something to be desired, but it works, it's accurate, and it's consistent. datacolor's also been working hard on improving their support. For monitor profiling there's rarely reason to buy the Elite over the Pro, but since you need projector profiling that doesn't apply here.
Works fine with 64-bit Vista (verified firsthand), and works with Windows 7 as well (per others and datacolor). 7 systems may need a workaround to install; it's documented on datacolor's site.
Really, it's the only option right now at that price point. To get projector profiling from X-Rite, it's either the ColorMunki (which is more expensive because it also does print profiling) or the even higher-end i1 Pro.
