RCicala Offline Image Upload: On
p.1 #1 · Lensbaby composer heads-up | |
I was originally pretty impressed with the build construction on the Lensbaby Composers (compared to the previous models, anyway), but a few months ago we noticed some of the screws that held the lens section (away from the camera mount, in front of the ball) had come out on a couple of our rental copies. But when we looked a little closer, it was obvious the internal screw threads were gone. Anyway, this made the front element quite loose and the lens not to useable, so we took a couple of the bad ones apart to see what was up. It turns out the internal structure is very, very soft plastic and its obvious that it cracks or fractures along the screw mounts - probably from torquing the lens over to maximum tilt here and there (here's four of the eight internal threads from two of these lenses we took apart). Best be gentle with these!!
