hfillmore Offline Image Upload: On
p.1 #21 · Considering Switching Systems | |
If you had the funds, say 3-5000, to really get into a basic sports "starter kit", then I'd say this:
Look at which lenses will do the best performance/cost ratio to do the job, and go for that system. EX., you want to do surfing. Best FL is 600mm. You can't afford that, so look at the 400mm lenses. You want a prime, for best IQ when using TCs. So what's out there? In primes, 3 choices - Canon 400 2.8, Nikon 400 2.8, and Canon 5.6. The 2.8s are 5-7K. Do you need 2.8 for surfing shots? Of course not. It's a daytime sport. Canon has a tack sharp 400 5.6 prime for about $1100. Nikon has none. Go for the Canon, and get a body to match.
Need a 17mm TS for architecture? Go Canon, Nikon doesn't have one. Need a macro with IS? Go NIkon, Canon doesn't have one.
Need a super fast focusing, tack sharp, crazy cheap lens for indoor basketball? The Canon 85 1.8 is it, for less than $400 new. Mate it with the 135 2.0 for about $750 used, and BINGO.
So in a better situation than you're current one, where you'd have 3-5K to spend, and you could start from scratch, I'd say figure out which lenses will give you the biggest bang for the buck, an go for whatever system has those lenses.
But in your current situation, with little or no cash, you don't have these options. Now I'm a Canon shooter, and am there basically on lens choice for my particular needs. But in your situation, I'd say that at this time, your greatest limiting factor is focus speed, buffer size, and FPS. I'd stick with the lenses you've got, and upgrade the body. As someone above mentioned, the prices of the D300 should be coming down when the new "S" version is out. Giet yourself a workable body, and get started making some money with the lenses you've got. As the money comes in, keep adding lenses. Keep buying good stuff, but second hand, along the way, and you won't loose much money on good glass down the line. It's on the bodies that you'll take the big hits ....... keep buying those used as well. I don't think you'll go wrong with a good used D300. And my God, in the Canon camp, I think you can get aused 1DMK2 right now for about $1200. Sheesh......guy's have been doing double spread layouts in sports mags for years with those bodies.
Enough of going nuts. Stop thinking.
Keep the lenses you've got, get yourself a good used D300.in a few months, forget the specs, start working, and learn to master what you've got.
Look, I'm not a pro. I do a lot of surfing photography here in PR. I use a Canon MK3, and a 600mm f4. I know two pros here in PR. They both shoot from the water, using water housings. They both get great shots, and make their living selling to mags, doing assignments, etc. One guy has 2 lenses - a Canon 10-22, a Canon 135, and two beat up 20Ds. The other guy has one 20D, a 10-22, and a 85 1.8., along with their water housings. Thats it. But they're out there in the water and shooting every day. They know their equipment, and they've developed the skill and knowledge necessary to get the shots. That's what it's really all about. My investment in photo stuff is easily 15 times what these guys have invested - and their shots, taken with ancient, inexpensive equipment from the water, will blow mine away every day. So man, just get a decent used body, master the stuff, and be out there every day. That's really what it takes.
Harvey
