erichard Online Upload & Sell: Off
p.1 #4 · Eg-s screen on a 5D MK I ? | |
I'm not sure, but I was thinking it was the reverse, that the EeS was slightly bigger, and the reason I say this is that I had the Maxwell EeS screen and it didn't just fall into the 5DII space without sanding or filing the edge (little nubbins) a little bit as I recall (it could be pushed in place, but wouldn't just drop in place as the EgS does). It fit, but just barely (meaning EeS in the 5DII). So that might mean the EgS would fit in the 5D slot with ease (logically, didn't have two cameras at the same time). Bill should know the dimensions as he works with both.
Aside from this issue, what I will say is, this was the best focusing screen I tried and solves all issues basically, but it took him quite a while to finish it, communication is pretty sparse (call him if you get frustrated, as I believe he is more of a phone guy than an email sort,) and it is a fairly expensive indulgence. It's a commitment to the alternative lenses basically.
I myself would be tempted to get the EgS in your situation. The 5DII really is arguably twice as good as the 5D in my opinion, and you will ultimately want to upgrade. However, I'm not sure if everyone will agree whether there's much of a difference between the EeS and EgS in terms of functionality. They may be the same apart from the subtle nubbins on the sides.
I guess your main question will be, is it too small for the 5D, if what I say above is correct. Probably not, but maybe. I would think being supported by at least the front and back supports and at least one of the sides would be enough to function properly.
BTW, I have a couple EgA focusing screens if anyone wants to buy one. I no longer use them, and one is basically new.
