Carmen Miranda Offline Image Upload: Off
p.1 #1 · Quadra EL Adaptor Modification | |
Howdy folks,
I'm really loving the new Quadra system so far.
I'm also happy that there is an adaptor for this little gem that allows me to use some of my favorite Elinchrom standard mods. But as many are aware, this Elinchrom Quadra EL adaptor is not rated for boxes larger or heavier than their 39" Rotalux and IMO that does not include their DO.
In most case this would not be a problem for me, but I have a shoot coming up in a couple days where I'd like to use their bigger strip box. Since I had a little time on my hands this afternoon, I decided to make the mount modification I have seen on this forum. I thought perhaps others might want to take a closer look since the Quadra is sure to be a huge hit and many are sure to push the limits of the adaptor.
All things considered I felt the modification worked out very well, even though my work leaves something to be desired. Good news it even held a 53" Octa with no creep, although though I have no intention of using this mod with a Quadra in the future. Nor am I recommending it. Fact is that as you strengthen one area you always put stress on another. However, I'm very confident that this modification will perform better than the stock mount with normal mods up through the DO. Proceed at your own risk and good luck.
Exploded view of Elinchrom Quadra adaptor and Manfrotto 2905 tilt swivel adaptor (replacement metal and Delrin washers not shown):
Elinchron Quadra EL adaptor before cutaway with Dremel tool:
Close-up of cut marks for Dremel tool:
Elinchrom Quadra EL adaptor after modification.
Close up of Elinchrom Quadra EL adaptor assembled after modification holding a MaxiSoft 27" beauty dish.
Modified Elinchrom Quadra EL adaptor holding a 53" Rotalux Octa.
The little mount that could.
