FM Actions & Plugins support
Workflow Guidelines
droplets and lightroom problems Go to previous topic Go to next topic
hardlyboring
Image Upload: Off
p.1 #1 · droplets and lightroom problems
I want to be able to run a droplet in lightroom on my raw images upon export that will run them through a few other actions in photoshop.
In photoshop I originally created an action started recording then did some levels and curves and then ran a bw action that I use and then sharpened using smart sharpen in all the tutorials online it said to have a save as step in my action so I did that. Now I created my droplet and then put it into the correct folder in lightroom. upon export from lightroom I get this droplet stopped working message and then lightroom just saves my Jpeg. This happens on both raw and jpegs in lightroom. I tried to take out the save as step and still I get the error message. Is this happened because I am trying to run an action withing another action? I am confused and have exhausted about every possible fix I could find through my research.
Any suggestions on how to run my droplet on preferably my raw files or else jpegs if necessary? I would like to run my action within the action because I have the action plus sharpening etc that needs to happen so I figured I could just record it all into one action and be done. but guess not.
Thanks
Doug
Jul 16, 2009 at 09:23 PM
hardlyboring
Image Upload: Off
p.1 #2 · droplets and lightroom problems
nothing?
Jul 17, 2009 at 12:01 AM
butchM
Buy and Sell: On
p.1 #3 · droplets and lightroom problems
Is it possible you exported 16 bit files and the action you are trying to run will only work on 8-bit? Or maybe it stalls due to a layer name being different or other missed item ....
Or it could be any little missing step that is not included in your action(s) try running a file through the droplet directly with out using light room and see if the problem persists.
Jul 17, 2009 at 12:49 AM
hardlyboring
Image Upload: Off
p.1 #4 · droplets and lightroom problems
no the action or droplet works fine in photoshop, and I working with 8bit files not 16. Still cannot figure out whats wrong.
Thanks though
Doug
Jul 17, 2009 at 03:38 PM
Lost password?
