dave chilvers Offline Image Upload: Off
p.1 #1 · Nikon 105 2.5 Ai-S stiff aperture ring | |
Cross posted from alternative gear forum, no takers
Anyway, lens is in good condition for it`s age (not sure how old but serial is 1018406) probably would be termed as mint by most shops. Focussing is smooth and positive (perhaps a little more free than my contax gear) no lubricant on iris and no dents or dings on front or built in hood.
The aperure ring is stiffer than any of my other Nikon lenses and certainly stiffer than my contax stuff. To the point where it shows up a slight movement in the adapter when used on a Canon.
I notice screws on the rear mount, would this give me access to the aperture mechanism? because I feel that it probably just needs a careful touch of lubricant. If so, are things and springs likely to fire out if I undo and remove that rear section?
Or what would you suggest? I don`t really want to send it to Nikon because that would push the cost up and maybe take the edge off of the purchase.
Thanks for any advice
