FM Actions & Plugins support
Workflow Guidelines
acr 5.4/lightroom/cs4 Go to previous topic Go to next topic
armandcp
Image Upload: Off
p.1 #1 · acr 5.4/lightroom/cs4
Dear FM folks
Hope someone can help me.
I just installed ACR 5.4 on Mac and I got some troubles. Could be all related or not.
I use CS4, LR 2.4.
Q1:
After installing ACR 5.4 in LR develop module I can't see in Camera Calibration ACR 5.4 , although the old stuff shows in as seen
here
Is that something expected ? If not any idea how to correct it ?
Q2:
Using the "Edit in .." function from LR, works ok with Elements, that is is presents me with options as seen here
But when choosing CS4 as my external editor, it does not present this option and opens the RAW (.CR2) file in CS4. In LR preferences I have set it this way
Any help is appreciated. Granted I would not like to have Microsoft approach , deinstall/reinstall that is.
Many thanks
A
Jul 07, 2009 at 06:41 PM
butchM
Buy and Sell: On
p.1 #2 · acr 5.4/lightroom/cs4
First off ... I don't believe you need to, or should "install" ACR in the LR develop module. If you updated LR to v2.4 that is all you need to do ... the ACR plugin is for PS and should be installed there.
In LR it will show the default version of ACR when your camera's file format were first handled by ACR/LR ... even though you have ACR 5.4 installed, it could be an earlier version when your camera was introduced .... that said, you will have all the available setting, options of the latest version of ACR/LR raw development.
Jul 07, 2009 at 06:52 PM
armandcp
Image Upload: Off
p.1 #3 · acr 5.4/lightroom/cs4
Thanks. On the second question is this something expected as well ?
I was not expecting to see CS4 opening the raw file from LR, but a TIFF copy , same as Elements.
Jul 07, 2009 at 07:01 PM
armandcp
Image Upload: Off
p.1 #4 · acr 5.4/lightroom/cs4
Guess I found my question.
So yes LR2->CS4 gets to CS4 in .CR2. But saving the saving the file, it gets saved into TIF and appears stacked in LR2.
Jul 07, 2009 at 07:39 PM
James_N
Image Upload: Off
p.1 #5 · acr 5.4/lightroom/cs4
The simple answer to your question is that Lightroom and Adobe Camera Raw will not work correctly if there is more than one version of the plug-in installed. And apparently you compounded the problem by installing a version of ACR in Lightroom. Lightroom is a standalone program and does not need to be updated with ACR.
My suggestion would be to use Finder/Windows Explorer to search for all occurrences of the Adobe Camera Raw file and delete them. And since you don't seem to know how to manually install the update, open Photoshop and go to Help > Updates and let the updating be performed automatically.
Jul 07, 2009 at 08:29 PM
armandcp
Image Upload: Off
p.1 #6 · acr 5.4/lightroom/cs4
Hi James
I followed the instructions in the readme file. On the splash screen "About LR .." I see ACR 5.4 . All seems ok. I guess I miss stated something. "After installing ACR 5.4 in LR develop .. " should have been "After installing ACR 5.4, in LR develop ..." which is a different thing.
Thanks all for help
A
Jul 07, 2009 at 08:51 PM
James_N
Image Upload: Off
p.1 #7 · acr 5.4/lightroom/cs4
Lightroom and Adobe Camera Raw share the same processing engine. However the update process for each is quite different.
Jul 07, 2009 at 09:07 PM
Lost password?
