UCSB Offline Image Upload: Off
p.1 #10 · Remove rain using PS or Action | |
There are a few ways to speed this up. One approach would be to create a new layer above the base layer. You can use the move tool to move this layer a small amount (say 10 pixels). Then place an inverted mask on the layer (when you click on the mask icon, have ALT pressed). SET YOUR LAYER BLEND MODE TO DARKEN. Then just paint with white (with the mask selected) to revel the shifted pixels (if you make a mistake, just press x to switch to black and correct, then switch back to white). This will allow you to quickly correct all narrow streaks.
You might experiment with blurring the underlying layer (but, get rid of white and other colors in the image because they will blur into the suits). This will give you a less accurate, but very quick base layer to paint in corrections.
This is probably about as fast an option as I can think of:
Slightly more difficult, but should get you good results. Copy you base layer (CTRL J) to a new layer. Select move tool and use arrow keys to move your image over enough pixels so the small streaks do not line up. Make sure the new layer is active. Go to Image > Apply Image. In the layer field, select your base layer. In the blend field, select darken. This should create a merged image where most of the streaks have disappeared (you can touch up any remaining problems with your paint brush/clone). Click OK and then create a inverted mask on this layer. SET THIS LAYER BLEND MODE TO DARKEN. Now with your mask selected, use the bush with white paint to simply paint over the streaks.
Here is what you get just brushing over the streaks quickly.
Edited on Jul 07, 2009 at 08:01 PM · View previous versions
