Archive 2009 · Oregon Coast Lighthouse
Wingspar
p.1 #1 · Oregon Coast Lighthouse
Not sure I like this at all, so open for comments.
Gary
Will Fly for Food.... and more Nikon stuff
Jul 06, 2009 at 10:50 AM
Charlie Shugart
p.1 #2 · Oregon Coast Lighthouse
Gary,
Part of the problem with the first shot is trying to get vertical buildings to look vertical. Unless you have a special lens designed to do that, about all you can do in-camera is back up and use a telephoto lens.
About the second photograph- I really like it. The composition is swell (I'm trying to get the word back into circulation), and the pattern of the bricks adds greatly to the success of the shot.
Charlie
Jul 06, 2009 at 11:02 AM
Wingspar
p.1 #3 · Oregon Coast Lighthouse
Charlie,
I used the chimney in the house in front of the lighthouse to straighten the vertical. It made the lighthouse look likes it leans to the right even more than before I straightened the chimney. I was about as far away from the light house as I could get. To get further away, one needs to go to the highway, and shoot from almost a mile away, so I’m stuck with this. I have a two shot vertical pano of this lighthouse, but not sure I like it enough to post, and the lighthouse part still leans to the right. I did take some shots from the distant vista point, and your right, everything looks vertical in that shot, but too much haze, and too much wind to hold the camera steady enough. Don’t really like the softness of those photos much, so not sure if I will process any of them or not.
The second shot was a hand held at 1/30sec, ISO 800. It was a narrow passage way with low light, and difficult conditions. Those brick walls are 3-feet thick.
Gary
Jul 06, 2009 at 11:48 AM
Charlie Shugart
p.1 #4 · Oregon Coast Lighthouse
Gary,
You pretty well summarized the problems of a photograph like the first shot.
There IS one possible solution that I have found sometimes works. It is this: back up as far as you can. Then, using the most extreme wide angle you have, shoot vertically, with the top of your composition being at the top of your viewfinder. Forget about what's at the bottom of the viewfinder- that can be cropped later however you want. Under the right circumstances (and if your lens is wide-angled enough), your camera will be close to a horizontal axis- thus "straightening" the lighthouse (or other). Rate the exposure at the lowest ASA equivalent possible because this method tends to waste space, requiring some enlargement in the processing.
Good luck.
Charlie
Jul 06, 2009 at 12:11 PM
greswolde
p.1 #5 · Oregon Coast Lighthouse
great advice from charlie there
the second shot is really cool, you have some great elements in there as well as great composition my only suggestion would be to try and darken the lower section of the hand rail a bit to shot it jumping out at you so much.
Cheers
Martyn
Edited on Jul 06, 2009 at 04:39 PM · View previous versions
Jul 06, 2009 at 01:46 PM
Amercko
p.1 #6 · Oregon Coast Lighthouse
second one is my favorite
Jul 06, 2009 at 02:46 PM
Wingspar
p.1 #7 · Oregon Coast Lighthouse
I was backed up as far as I could go without having to crawl over a fence, and plunge hundreds of feet to the ocean. I was using an 18-35, but I shot it at 24mm. I’ll certainly remember your advice the next time I shoot a lighthouse.
I actually did darken the handrail as much as I could. There was a light above that part of the rail that shined right onto the lower part of the rail, and the upper part of the rail didn’t get the light.
Thank you.
Gary
Will Fly for Food... and more Nikon stuff
Jul 07, 2009 at 10:33 AM
digitalbug30d
p.1 #8 · Oregon Coast Lighthouse
a fan of the 2nd one...nice
Jul 07, 2009 at 10:03 PM
m. goodwin
p.1 #9 · Oregon Coast Lighthouse
+1.
marty
Jul 07, 2009 at 10:49 PM
Bill C
p.1 #10 · Oregon Coast Lighthouse
Gary - another vote for the 2nd one! I realize the perspective problems with a shot like number one .. to me it looks as though the tower is lifted off the ground.
Thanks for sharing.
Bill
Jul 08, 2009 at 09:58 AM
Wingspar
p.1 #11 · Oregon Coast Lighthouse
m. goodwin wrote:
+1.
Thank you both. I agree that the second one is the better of the two.
Thanks. Yes, the lighthouse does look like it is lifted off the ground on the left. This is the first time I’ve shot a lighthouse while being so close, but there isn’t enough ground to back away from it, so it’s shoot it closeup, or shoot from a turnout on the highway about a mile away. I just might have to post one of those shots from the highway, even tho they aren’t very sharp. Too windy to hold the camera steady.
Gary
Jul 08, 2009 at 10:08 AM
Bill C
p.1 #12 · Oregon Coast Lighthouse
Wow! Now I see what you mean! (how about a shot from a parasail?
I like this shot as well.
Bill
Jul 08, 2009 at 10:33 AM
Wingspar
p.1 #13 · Oregon Coast Lighthouse
You know, I took some shots of this lighthouse from the air on a perfect day for doing it years ago, and have never been able to find the photos. The cool thing about that day, is right after we passed the lighthouse heading south, and right after putting the camera away, my passenger noticed I had a pair of Oregon National Guard F-15's just off my right wing. Close enough to see their eyes. Put the camera away just a tad bit too soon.
Gary
Jul 09, 2009 at 12:08 AM
sbeme
p.1 #14 · Oregon Coast Lighthouse
Second is great!
Scott
Jul 09, 2009 at 07:51 AM
