1953hogan Offline Image Upload: On
Hello,
I shoot some night soccer, too. I was typing at the same time that Russ was, and after reading his post I think his advice is very good for you.
Yes, I think you should shoot AI servo.
I don't think 1/250 is fast enough. At night, I would hope for at least 1/500 and will increase my ISO as high as 6400 if necessary. I shoot with a Nikon D3.
Your F/2 lens should be a great advantage at night, but it is short so you need to wait for the action to come right up close to you. Don't press the shutter unless the players are right up close in the viewfinder.
I would think that using center point focus and then just aiming at the chest of your subject would help you.
I would not shoot Tv mode, personally. At night, with your lens, I would shoot Av mode, aperture set at F/2, and check the shutter speeds to see if I'm getting at least 1/500 or better yet, 1/640. If not, I would increase my ISO.
Actually, if the field lighting is consistent or if you plan to stay in one spot for the whole match, you could try shooting in manual mode, too. Here I would set the aperture at F/2 and then take an educated guess for ISO and shutter speed. I'd check my first few exposures and then settle in at some settings when I'm confident the exposure is good, but again, I would want to try to get 1/500 or at least 1/400 minimum.
Best of luck with your shooting.
Steve
