jvarszegi Offline Dedicated FM Upload & Sell: Off
p.1 #4 · Anyone used EF-530 DG ST? | |
I already have radio triggers on the way, and don't plan to use optical slave mode on any flash I buy. The 430EX is nice (I used to have a 420EX and liked it plenty), but if I can get a flash for half the money that offers more power and meets my needs, I will.
A note about recycle times: if you use very little flash to begin with, as I do, many flashes would fit the bill for most single-flash event uses. When posing groups, recycle time should not matter as much. Reliability and maximum power of course always matter, and fast recycle times are always desirable.
The 430EX has a guide number of 141' / 43m @ 105mm. Some of the third-party flashes I'm considering now:
Bower SFD926C: E-TTL, wide-angle diffuser panel, GN 125' / 38 m @ 85mm, $110
Nissin Di622: E-TTL II, GN 144' / 44m @ 105mm, 6 power levels down to 1/32nd, $150 (I figure I have liked their Ramen noodles in the past, why not try the flash?)
Vivitar DF 383: E-TTL, GN 148' / 45m @ 85mm, 5 manual power levels down to 1/16th, $130
