FM Forums | General Gear-talk | Join Image Upload
B&W outdoor.case Go to previous topic Go to next topic
L33t
Image Upload: Off
p.1 #1 · B&W outdoor.case
Does anyone have the picture of B&W outdoor.cases? I want real images to see the actual size of it, I know I can find size on website.
When I looked at 67 and 68 it looks 3 times as high as 70 but it cm it's only few cm higher. I need to know if type 70 is 50% less high than 67 and 68 or something, I need to carry this bag with me on the plane.
Jul 04, 2009 at 07:32 PM
Lars Johnsson
Image Upload: Off
p.1 #2 · B&W outdoor.case
67
Dimensions
Inside dimension: 535 x 360 x 245 mm
Outside dimension: 590 x 430 x 285 mm
Package dimension: 0 x 0 x 0 mm
Volume: 47 L
Net weight: ca. 7.30 kg
68
Dimensions
Inside dimension: 590 x 425 x 295 mm
Outside dimension: 665 x 500 x 335 mm
Volume: 74 L
Net weight: ca. 10.50 kg
70
Dimensions
Inside dimension: 675 x 425 x 210 mm
Outside dimension: 755 x 500 x 250 mm
Volume: 60 L
Net weight: ca. 9.00 kg
Jul 04, 2009 at 08:26 PM
L33t
Image Upload: Off
p.1 #3 · B&W outdoor.case
That's exactly what I wrote, I know dimension but images on website makes size of 67-68, 3x higher than 70. Doesn't make sens :S
Jul 04, 2009 at 08:42 PM
Lars Johnsson
Image Upload: Off
p.1 #4 · B&W outdoor.case
If you know the dimension, then you know it's height Or do you think the dimension will change after you see a photo
Jul 04, 2009 at 09:23 PM
GeorgeK-NJ
Image Upload: On
p.1 #5 · B&W outdoor.case
I looked at the Web site and I can understand your concern!.
The dimensions and the pictures do not seem to match up. The 67 and 68 while listed as 28.5cm and 33.5cm high, look a lot taller then the 70 which lists its height as 26cm. 3x is a bit of an push, but I feel your concern. The pictures might not be the same scale, which could have a little to do with it, but still.
It wouldn't be the first time that the dimensions were posted wrong on a Web Site.
Good luck.
Jul 05, 2009 at 10:26 AM
L33t
Image Upload: Off
p.1 #6 · B&W outdoor.case
Good luck.
Thanks for understanding me but still, anyone have real picture of them?
Jul 05, 2009 at 12:40 PM
Lars Johnsson
Image Upload: Off
p.1 #7 · B&W outdoor.case
Take a look in Bangkok's Fotofile shops. They sell the B&W outdoor cases
Jul 05, 2009 at 01:31 PM
L33t
Image Upload: Off
p.1 #8 · B&W outdoor.case
:S Is there any chance I get a pirate copy of the bags or something from China? haha
But it seems stuff cost more in Thailand when I compared. 7% refunds right?
Jul 05, 2009 at 10:16 PM
Lost password?
