Rodolfo Paiz Offline Image Upload: On
p.1 #5 · Nikon PC-E lens question | |
As usual: it depends. If we assume that you're going to tilt down a degree or so to get the appearance of "infiinite DOF", then I see at least two ways to do the shot:
1. Keep the shift as it is (which, if you're tilting down, is left-right). Then take two shots: one shifted fully left, the other shifted fully right. Stitch, and you're done.
2. If you want reeeeaaaallly high resolution in your landscapes, then have Nikon rotate the functions so they are on the same axis. Place the camera in landscape orientation on the tripod, tilt down to get the focus plane where you want it. Now, take two shots (shifted up and shifted down), and these two shots will later get stitched to become the first "panel" in your bigger pano. Rotate the camera left or right using appropriate pano gear, and continue to take pairs of shots to make more panels. When you go home, stitch each vertical pair together, then stitch all the horizontal panels together. Lots more work, lots more megapixels in return.
So it's still up to you. Try it first the way it comes from the factory; then, if you feel the need, get one or all changed over. There is no right answer... you have to find your own answer that works for you.
