FM Actions & Plugins support
Workflow Guidelines
Archive 2009 · Matching color balance two images
matonanjin
p.1 #1 · Matching color balance two images
There is some way to use the eyedropper in CS4 to match the color balance of one image to another. I shot this horse show a few weeks ago under gas lamps which were constantly changing their color balance. I need to balance the color in this two images for them to use for an ad. The first one is pretty close. The second one looks like a completely different horse. I can't just save the curves from the first one because the light has completely changed for the second one.
Seems there is some way to take a sample from the first, say from the sand or the horse's coat, and then match it in the second. does this make sense?
2
Any suggestions are appreciated. I need to get these to them for an ad deadline.
Jul 02, 2009 at 05:21 PM
CircleMGraphic
p.1 #2 · Matching color balance two images
On my monitor, which is calibrated, the color balance looks off in both of these images. The difference in the "color balance" may also be caused by your exposure. Most arena lighting is fluorescent and has "cycles" that can mess with exposure. The second image looks almost overexposed causing a color cast issue. These are tricky to get the images alike. Work with your exposure in PP to get the images close to one another and then work with the color temp. First image appears to have a megenta cast while the second appears greenish. Hope this helps and good luck.
Jul 02, 2009 at 05:34 PM
Weiyang Liu
p.1 #3 · Matching color balance two images
perhaps try to adjust in LAB color space.
Jul 02, 2009 at 05:40 PM
UCSB
p.1 #4 · Matching color balance two images
Looking at these images, I would say that you attempted to white balance them using a white part of the image that was clipping in one of the RGB channels. Go back and select two new neutral points where there is no danger of clipping and try to use the same material/point when you white balance each image. That should get you much closer. If further adjustment is needed, than put a color sampler point on the parts of the image that you are trying to match in both images. Create a curves adjustment layer in the image you want to match and then adjust the individual RGB channels to tweak the color while watching your color sampler points. Make sure that you start the process with the exposures balanced between the images.
Jul 02, 2009 at 05:42 PM
UCSB
p.1 #5 · Matching color balance two images
Another approach ... that is very quick and easy is to use the image adjustment command "Match Color ...". One click, but gives you less control over the final results.
Jul 05, 2009 at 06:33 PM
UCSB
p.1 #6 · Matching color balance two images
Actually, I should have mentioned that Color Match is a very powerful adjustment where you can use selections in the two images to produce very good matches ... it is a lot more than the one click method I mentioned above. It is good for ads, catalogs and other applications where you want good matches. Very good for matching skin tones in images.
Jul 12, 2009 at 04:20 AM
