gugs Offline Image Upload: Off
p.1 #12 · Private Helicopter Outing, What gear? | |
a few hints: two bodies with a 24-70 and a 70-200VR is the best combo. Note that I put the 70-200VR on a D2x to get more reach... up to you to decide if you want to add a TC or use the crop mode on the D3x if your need more than 200mm magnification on FX.
Check your shutter speed, because vibration can be an issue. Check your first pictures at pixel level (pixel peeping is REALLY important to be sure, and don't forget there are huge lighting differences between a dark building and a shot with the sky in it). I selected my settings on the ground and my first pictures were blurred. Luckily I checked quickly enough to increase my ISO to get the proper shutter speed (VR active is helping but is not enough). This is of course not really an issue with the 24-70 on a sunny day...
The best place is behind the pilot, on the other side with the door removed, and depending on the weather/temperature don't forget to wear a shirt to protect your arms, the wind can really get your arm very cold even if the temperature is reasonably high...
Be VERY careful with the seat belt, same type as in a classical airplane... a wrong move and you are not secured with all the possible consequences... as suggested foresee a piece of tape/rope/whatever to double lock it.
Next to that, have fun, it is just a wonderful experience.
And I forget: agree with the pilot on what you want to shoot, how many times you want to fly above a specific location, tell him when you are done, if you want to go up, down, left, right, slower, whatever, a short discussion can help make things clear.
With the headphones they are using, there is no problem to communicate with the pilot during the flight. It is a bit risky/dangerous to switch lenses or do anything else then taking pictures with your cameras, depending on some sudden movements (due to temperature differences for instance) you could drop something quite easily...
Hope this helps...
Guy
