Archive 2009 · outdoor music shoot- clouds/light
antsy_phoenix
p.1 #1 · outdoor music shoot- clouds/light
Someone is throwing me a bone and asked me to do a shoot for a classical music CD. Outdoors, cloudy/misty/forest/lake background, 1 subject, who has to be still be recognizable when the image is reduced to a tiny thumbnail on internet marketing.
I know its preposterous, but I've never used anything but natural light. I don't even own anything external. To this point I've just stuck with what I know, and frankly, been a bit intimidated by the lighting subject. However, its probably come time to get over it because in this case I think external lighting might give me the extra boost I need to have some more composition flexibility while still maintaining the subject's recognizability.
I use a Canon 50D, and have to use a Canon 50mm 1.8 fixed as I'm in a location where I can't rent an L lens for the day like I would otherwise do. They've seen some test shots, and seem ok with it so far. The test shots have the desired cool color tone, but I am also thinking that lighting might help to warm up the instrument's natural wood color... but have no idea how to pull that off.
Can someone please, please help me with some suggestions? I'm saving up for lenses, and as I mentioned, lighting isn't really my forte, so bang-for-the buck is a priority. ~~~thankyou~~~
Jul 01, 2009 at 01:54 AM
bacilonur
p.1 #2 · outdoor music shoot- clouds/light
When is that shoot scheduled? You're asking for advice on something that some people who've owned lights for years still haven't mastered.
The safest choice would probably be to get one or two reflectors (Lastolite Trigrips are the shiznit) and just use those. Lights get expensive real fast once you factor in triggers, adapters, Eneloops and a decent charger, stands, etc. If you want to warm up the wood, you can use a sunfire reflector, those are great.
Jul 01, 2009 at 02:45 AM
cgardner
p.1 #3 · outdoor music shoot- clouds/light
Outdoors the nemesis is contrast. Your camera can record about a 7 stop range of detail, but a typical outdoor scene might have a range of 10-12 stops. Since exposure must be made to record highlight detail that results in a loss of several stops of shadow detail and the rendering of the midtones much darker that seen by eye: i.e., they look darker than "normal" in a photo with optimally exposed highlights.
There are several possible contrast reducing strategies to overcome that camera limitation: 1) use flat natural lighting, 2) artificially flatten the natural lighting by using a scrim, 3) shoot into the shadows of the natural light and use a reflector for fill, 4) shoot into the shadows of the natural light and use flash for fill.
You'll get the most dramatic lighting effect by shooting into the shadows and adding fill, but that's also when the natural light has the most contrast and you'll need fill from a reflector or flash. Conversely flat lighting has less contrast and will allow the camera to record a greater range of detail in the shadows when the white textured details are retained with correct exposure, but pulling off a interesting looking shot in flat light is a bit more difficult, requiring planning to contrast the parts of the subject you want seen against the background. Pray for an overcast day which will have lower contrast. Using a scrim is way to create artificial overcast but probably isn't practical for your situation.
Fill flash is the simplest solution logistically and the easiest to control. All you'd need to do is keep the flash on / above the the camera, shoot into the shadows of the natural light and first correctly expose the backlit highlights, then add flash power in the foreground until you get sufficient detail revealed. The net result is a photo which has well exposed natural highlights and a full range of shadow detail revealed by the fill flash.
The important technical things to realize about "fill" flash are:
1) Its not really fill outdoors: When you shoot into the shadows of the natural light the sky the subject is facing becomes the fill and the flash becomes the "key" light which creates the shape revealing highlights. Thus in that situation you need to position the flash as you would a key light, above the head of the subject, to achieve a flattering highlight /shadow pattern on the face.
2) Flash exposure is only correct at one distance: When shooting in natural light its quite easy to use foreground objects to frame something further back in the scene. But because flash power falls off 2 stops (more or less) each time the distance is doubled that doesn't work. The foreground objects will either fool the ETTL metering resulting in underexposure of the middle-ground, or if flash is adjusted to correctly expose the middle-ground the foreground will be over-exposed. Bottom line is that you need to keep what you want correctly exposed with the flash (i.e. the face and hands) closest to the flash, and also keep everything you want to be correctly exposed a similar distance to the flash.
For example, you wouldn't want to shoot a pianist with flash fill from the far end of a grand piano over its length because when the flash is adjusted for correct exposure of the face and white clothing the foreground of the piano would be blown out. Instead you'd want to compose the shot as a side view so the artist and piano are equidistant from the flash, or alternately compose the shot so the artist is in the foreground and the piano is visible behind, with the flash falling off and making it darker and less distracting.
One final piece of advice: bring a ladder. When shooting from eye level the high angle of even indirect natural light will cause the eye sockets to be shaded by the brow. Fill flash can't really help much in that situation because as you add fill to the sockets the same amount of light gets added to the highlights next to them. The solution to the dilemma is quite simple, raise the face up into the light so it reaches the eyes. You'll then need to raise the point of view of the camera to capture a flattering facial angle; hence the importance of the ladder.
Raising the camera is also a good strategy for dealing with distracting backgrounds, near/far size distortion, and flash fall off. In a situation like described earlier, shooting over the length of a grand piano at the musician if shooting from the top of 8ft ladder the downward angle would result in more even lighting because when elevated over the camera the light would be more equidistant to both ends.
Chuck
Jul 01, 2009 at 10:15 AM
antsy_phoenix
p.1 #4 · outdoor music shoot- clouds/light
I have about a month to figure this out. I am virtually guaranteed an overcast day at this location. If I'm struggling, I may have an opportunity to try something in a different location within another 2 months.
The lastolite trigrips look awesome thanks @bacilonur.
Chuck, your suggestions are ideal- especially because they're so helpful for using the natural light. LOVE the ladder idea- thankyou. Praying for clouds.
Portability of this stuff is a major concern, anything not packable by 1 person over rough terrain is out.
Jul 03, 2009 at 06:05 PM
antsy_phoenix
p.1 #5 · outdoor music shoot- clouds/light
Just a followup post, they've narrowed the proofs to 6 images taken from slightly above. I was up on rocks, as per @cgardner's ladder suggestion. Concentrated on the socket light you mentioned, and came away with many satisfactory shots. The other four images selected were silhouettes. That surprised me but underscored the benefit of seeking range of content despite what the client _says_ they're looking for. I learned about lighting on this one, but still have a long, long way to go. At any rate- **thankyou** for the dynamite suggestions!
Jul 24, 2009 at 06:36 PM
